Date/Time: Sun, 22 Dec 2024 11:46:13 +0000
User Contributed Studies
View Count: 9634
[2015-05-28 17:57:20] |
The User Contributed Studies file is now distributed as a separate file. It is attached to this thread. Here are instructions to use it: https://www.sierrachart.com/index.php?page=doc/doc_DLLUsage.html File updated: 2015-06-05 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-05 17:15:36
UserContributedStudies.dll - Attached On 2015-06-05 17:15:29 UTC - Size: 1.25 MB - 923 views |
[2015-06-05 17:19:04] |
You need to save this DLL file to the Data Files Folder which is usually C:\SierraChart\Data We do see the study named MAMA in this latest file attached to post #1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
