Date/Time: Sun, 22 Dec 2024 19:21:35 +0000
Turn off Sierra Historical data and Turning ON Historical data from provider
View Count: 804
[2015-05-28 16:47:50] |
User44790 - Posts: 21 |
Hello, How can I Turn off Sierra Historical data and Turning ON Historical data from provider? Thank you Jaro |
[2015-05-28 17:34:57] |
You cannot in the case of OEC. And there definitely would be no reason at all to do this.
