Date/Time: Sun, 22 Dec 2024 14:40:20 +0000
usercontributedstudies.dll
View Count: 1042
[2015-05-28 10:53:44] |
User43684 - Posts: 4 |
Hello, I have clean install and if i want use study from usercontribedstudies this section complete missing in my Sierra, i have 1259 version before same problem. |
[2015-05-28 16:38:23] |
I did not find any answer there. If i want to add study i do not see "usercontributedstudies" as before in the older versions.
[2015-05-28 17:57:46] |
Refer to this thread: User Contributed Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-28 19:01:49] |
Thanks. Solved.
