Date/Time: Mon, 21 Sep 2026 04:38:10 +0000
Levels from one chart to another
View Count: 1193
| [2015-05-28 08:06:28] |
| User17477 - Posts: 65 |
Hi SC Support, My analysis is typically conducted on the emini s&p500 using volume profile but my trades are executed on the SPY ETF as this allows better position sizing for my modest account. When it comes to placing orders I have to roughly translate the order level from emini s&p500 to the SPY ETF and I would like to find an easier way to do this. Do you have an suggestions based on the SC indicators etc? Thanks |
| [2015-05-28 08:19:19] |
To clarify, I am not looking for automated order entry just a way of transposing levels from one chart to another if possible.
| [2015-05-28 09:37:53] |
We recommend looking at the Spreadsheet study: http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-05-28 10:12:10] |
Any similar examples that I can learn from?
| [2015-05-28 17:06:31] |
No, but you would probably need to reference data from the emini s&p500 chart when using the Spreadsheet study. This can be done by using the Study/Price Overlay study. Here are instructions: http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
