Date/Time: Sun, 22 Dec 2024 19:47:59 +0000
EUREX was close (Bank Holiday) but data in Chart
View Count: 871
[2015-05-28 04:48:58]
nicktrader - Posts: 715
For 2015-05-25 I got data but on that day was a Bank Holiday and the exchange was closed. Is there a way to eliminate the data of that day (see screenshot)
imageBank Holiday.png / V - Attached On 2015-05-28 04:45:28 UTC - Size: 42.85 KB - 366 views
[2015-05-28 05:08:41]
I solved the problem by myself. I made ==>> Edit/ Delete all data and Download.
Now it works correct.
[2015-05-28 17:21:26]
Make sure you are on version 1259 or higher of Sierra Chart. This problem has been solved so it will not happen again.
