Date/Time: Sun, 08 Sep 2024 00:14:10 +0000
VOLUME PROFILE DAILY BY DAY OF LAST MONTH
View Count: 1162
[2015-05-27 19:10:32] |
User60358 - Posts: 47 |
gOOD EVENING . i NEED TO SEE LAST MONTH OR FEBRUARY VOLUME PROFILE OF FTSE MIB ( INDEX OF ITALY ) . hOW CAN i DO THIS? tHANKS
[2015-05-27 20:46:41] |
Do you already have a chart of FTSE MIB ?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-27 20:47:04
[2015-05-30 08:46:36] |
Yes, i ve got
[2015-06-02 04:43:16] |
So you will need to use the Volume by Price study: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html Set the Volume Graph Period Type study Input setting to From Start Date-Time to End Date-Time. This setting is documented here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#Settings You will need to set the Start Date Time and the End Date Time using the corresponding Input settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-02 04:46:06
[2015-06-10 17:41:43] |
Good evening. I didnt resolve my problem. I try explain .. I'like a chart with volume profile daily of some time back, for example about february, like th of 21 february that i'll send you as first file in attachement But, when i tried with your istructions, I got 1 bar that hasn't peack and valleys, like file n. 2 i'll send now to you. So I can't work whit volume by price of the bar in the past months, because I see only the POC. Can I reach a volume profile , volume by price, like the first file. Thamks |
[2015-06-10 17:51:52] |
Good evening. I didnt resolve my problem. I try explain .. I'like a chart with volume profile daily of some time back, for example about february, like this of 21 february that i'll send you as first file in attachement But, when i tried with your istructions, I got 1 bar that hasn't peacks and valleys, like file It is a RECTANGLE , AND NOTHING MORE. So I can't work whit volume by price of the bar in the past months, because I see only the POC. Can I reach a volume profile , volume by price, like the first file. Thamks |
![]() Attachment Deleted. Attachment Deleted. Attachment Deleted. Attachment Deleted. ![]() Attachment Deleted. |
[2015-06-10 17:53:19] |
For accuracy you need to use the Volume by Price study only on an Intraday chart for accuracy. Not on a Historical Daily chart. So you want the Volume profiles to be 1 day in length each? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-10 17:53:37
[2015-06-10 22:28:01] |
YES, I WANT VOLUME PROFILE TO BE 1 DAY IN LENGHT EACH , OF LAST MONTHS.
[2015-06-11 05:08:15] |
OK therefore only use an Intraday chart and follow the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.html#Steps Be sure to follow specifically step 10 in addition to the other steps. You cannot use a Historical Daily chart. It must be an Intraday chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-12 18:38:35] |
I tried with intraday chart, but i have got little accuracy. Furthermore I didn't reach volume profile 1 day each for the period i'd like, 18-22 february..I reached a unique bar for the period, but I want multiples bar 1 day each on length for the same period, 18- 22 febraury, as I've got usually when I see an intraday chart of current days. So, do you have or not this feature?
[2015-06-12 19:05:46] |
Post an image of the chart so we can see what you have right now. Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-15 18:38:25] |
http://www.sierrachart.com/image.php?l=1434392939934.png http://www.sierrachart.com/image.php?l=1434393319991.png Here images you required...In the first, what i reach when i ask volume profioe 1 days each for period 18--22 february or other periods in the second, wath i reach when ever with intraday chart, I'd like to see volume profile daily Thamks |
[2015-06-15 18:47:22] |
Neither of these are Intraday charts. We said that you need to only use an Intraday chart. Go to one of those charts and select Chart >> Chart Settings. In the list box that says "Historical Chart" select "Intraday Chart Only" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-15 22:58:52] |
OK, I DID. BUT NOTHING, THE CHART DOESN'T GO BACK TO FEBRUARY EVEN IF I CHECK IN STUDY VOLUME BY PRICE, volume graph period type as from start date to end date and in start date i type 18/0272015 and at the end date I type 24 february 2015
[2015-06-17 16:50:04] |
Good evening. I told you in the last message thatr even with intraday charts the problem is the same . Can you help me ? |
[2015-06-17 17:21:06] |
Open an Intraday chart for the symbol that you want. Follow the instructions here to make it a Continuous Futures Contract chart so it will go back to February 2015: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts Make sure the Days to Load setting in Chart >> Chart Settings for the chart is set to 186. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-17 20:04:06] |
I'm sorry, it doesnt work..Please, Is there a possibility to work together with team viewer to set this chart?
[2015-06-17 20:11:50] |
OK, Now, I did , but I reach only 1 day at the time , if I set more days, for example 7 days, I reach an unique volume profile |
[2015-06-19 05:22:27] |
Yes, we can use remote assistance. When you are available let us know through an Account Support Ticket here: https://www.sierrachart.com/usercp.php?page=SupportTickets And we will provide you further instructions for us to connect to your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
