Date/Time: Sun, 22 Dec 2024 19:04:43 +0000
What is the feature to overlap new objects over old
View Count: 837
[2015-05-27 17:31:05] |
User34124 - Posts: 279 |
Example, by default I draw green rectangles. If I draw another rectangle over an existing one, the new object visually takes priority How do I do this bar the transparency feature |
[2015-05-27 18:18:27] |
There is no way to change the drawing order of Chart Tool Drawings unless you delete them and redraw them in the order that you want.
