Date/Time: Mon, 23 Dec 2024 16:42:15 +0000
CQG - FIX field incorrect 'Illegal Price' on 5 year t-note
View Count: 1929
[2015-05-27 13:10:15] |
dmh - Posts: 9 |
I received following native reject on a limit order at 119'26.75/32 for F.US.FVAM15: Info: FIX field incorrect 'Illegal Price: '119.835937 contract 'ZFM5' (ticks in 0.0078125, CAB of 0)' ExchangeRejectCode = 1011[] you can see the full price decimal should be 119.8359375 (the 5 got truncated so it was no longer to tick size) Is there some way to fix this? |
[2015-05-27 18:19:48] |
We can fix this. Just give us about one day.
[2015-05-28 07:11:52] |
This will be solved in the next release coming out in a couple of days. The changes are rather involved. We were previously relying on a C++ formatting function but that had a limitation.
[2015-10-13 18:33:57] |
User931283 - Posts: 55 |
I have a problem: On Version 1300. CQG, FIX connection (I think). Trading E-mini F.US.EP I had traded live on this connection back around July 1 on then-current SC version. All was well. I ran simulation from July 15 through today. All was well. I have not changed anything since it worked in July. When I tried to resume Live Trading today, I got "illegal price" "FIX field incorrect" and error code 1101, like the above poster's problem. In CQG's error message, the decimal is off by 2 places: Shows 200430.0 If I don't hear back in a couple of hours, I'll post this as a new thread. |
[2015-10-13 21:28:44] |
We are going to be testing this to determine the problem.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-10-13 21:28:53
[2015-10-14 03:21:12] |
We have not been able to duplicate this problem. Perform a Full Reset of Symbol Settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps And follow the instructions here to make sure they are applied to the chart you are using for trading: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-10-14 13:29:24] |
That seems to have fixed it. Thank you so much for such a quick response and solution. |
