Date/Time: Sun, 22 Dec 2024 19:11:52 +0000
Volume profile issue
View Count: 790
[2015-05-27 10:23:01] |
User11942 - Posts: 298 |
Hello SC team, I noticed that when Display above price bars option is set to Yes, POC/VAH/VAL lines (which are set to display with profile in Draw mode) will disappear. How can I fix that? v.1256 Thanks.
[2015-05-27 10:38:10] |
This has been solved already. Update Sierra Chart to the latest release.
