Date/Time: Sun, 22 Dec 2024 20:51:28 +0000
Customize Keyboard Shortcuts adding command
View Count: 1042
[2015-05-27 02:34:56] |
User567294 - Posts: 47 |
These following trading order type can be add into customize keybaord shortcuts list? 1,Sell Traling Stop + Bid -3 ticks 2,Buy Traling stop + Ask + 3 ticks 3,Buy limit order chase 4,Sell limit order chase thanks Rex. |
[2015-05-28 07:15:04] |
We will see about these.
[2015-07-19 13:03:33] |
any update on this issue? thanks Rex. |
[2015-09-01 06:57:42] |
any update? can this adding into shortcut config list? thanks rex |
[2015-09-01 07:27:00] |
There are no plans for these at this time.
