Date/Time: Sun, 22 Dec 2024 14:15:47 +0000
DTC question
View Count: 961
[2015-05-26 23:21:23]
onnb - Posts: 662
Have an app that needs to communicate with SC and thinking of using DTC for this.
The general flow is that:
App receives quotes from SC
App receives account info and updates from SC
App receives order updates from SC
App sends order actions to SC
1. Assuming SC is connected to trading account with data feed, this appears to be basic scenario for DTC that is supported by SC - right?
2. App would need to receive notification for order updates on the account regardless of the order origin - the order could have originiated from SC, the app or from some other app like a transact Dom. I'm assuming that DTC implementation would report on all order activities in the account?
[2015-05-27 04:26:57]
1. The capability to support this has not yet been developed but it is going to come.
2. When this capability is implemented, this will be supported.
[2015-05-27 06:15:18]
onnb - Posts: 662
Just for our planning purposes, any ballpark idea on when?
[2015-05-27 07:15:01]
There is quite a lot of work to put this together. We expect to be starting on this in about a month from now and would probably take about 2 to 3 months of development.
[2015-05-28 17:41:16]
onnb - Posts: 662
regarding #1 and your answer #2. We are looking into starting immediately with what is currently available and later adding what is missing.
Can you be more specific what parts of #1 are currently supported and what is not?
[2015-05-28 17:47:03]
1. Trading is not supported. Only market data through the DTC relay server:
https://www.sierrachart.com/index.php?page=doc/doc_RelayServer.php
[2015-05-28 17:49:20]
onnb - Posts: 662
1. App receives quotes from SC
2. App receives account info and updates from SC
3. App receives order updates from SC
4. App sends order actions to SC
1&2 supported
3&4 not yet supported
yes?
[2015-05-28 17:55:34]
Only 1 is supported now.
[2015-05-28 18:10:52]
onnb - Posts: 662
In general, is it correct to say that SC does not support to be the "server" side in the DTC api's?
For example, can I send SC this request and expect to get a response?
http://www.sierrachart.com/index.php?page=doc/doc_DTCMessageDocumentation.php#Messages-SECURITY_DEFINITION_FOR_SYMBOL_REQUEST
[2015-05-29 04:48:24]
Yes, not at this time.
No, this will not work.
