Date/Time: Sun, 22 Dec 2024 19:09:58 +0000
Renko Bar Chart - Chart Values Incorrect
View Count: 919
[2015-05-26 20:35:54]
user58907 - Posts: 83
For the symbol USDMXN I have a Renko Bar Chart set to 83 ticks. Setting is for Renko Brick with Wicks, tick size is 0.0001,Bar Period type is Renko Bar (in ticks).
As an example, there is a bar that opened at the low and closed at the high. When the crosshair is positioned over the bar, the values are;
O - 15.2477
H - 15.2554
L - 15.2477
C - 15.2477
Due to these errors, Open to Close doesn't show as 83 ticks, but is a varying figure.
I've tried closing and re-opening, and changing the tick setting to another number then back to 83 ticks, the error still persists.
Using SC 1224, this chartbook is set up to receive data from another SC installation.
[2015-05-26 20:41:45]
Provide an image of the chart showing this bar, by following these instructions:
[2015-05-26 20:56:26]
http://www.sierrachart.com/image.php?l=1432673734528.png
[2015-05-26 21:04:50]
I'm afraid the chart values do not show in the image, though I do have them on screen.
I have a screen capture in a Word file which is clear, but it doesn't copy clearly to any image file format.
Date Time Of Last Edit: 2015-05-26 21:12:02
[2015-05-27 03:43:33]
You need to look at the Renko Open and Renko Close values in the Chart Values window. This is documented here:
https://www.sierrachart.com/index.php?page=doc/doc_RenkoCharts.html#RenkoOHLCValues
[2015-05-27 07:22:36]
Thank you, I see the O/C values are different than what is displayed in the chart values bar.
In the chart attached, the O/C values for the bar marked one (bar above the number 1) were both 15.2477, which as you see from the bar is illogical.
In any event, I see I can get the correct Renko values for any bar in the Tools Values Window, so this will meet my needs.
http://www.sierrachart.com/image.php?l=1432710849266.png
