Date/Time: Sun, 22 Dec 2024 19:52:50 +0000
[User Discussion] - Chartbook Communication
View Count: 1025
[2015-05-26 20:21:57] |
Richard Novak - Posts: 24 |
Hello, I have an automated trading system written using ACSIL where I need to communicate some information between two chartbooks. I'm currently using a SQL Server database to do this but would like to use some direct interprocess communication method if possible. The two chartbooks may be in the same or different SierraChart instances. What approach would you recommend to achieve this? Thank you |
