Date/Time: Sun, 22 Dec 2024 19:17:19 +0000
Multiple tiick charts
View Count: 846
[2015-05-26 19:06:49] |
User699694 - Posts: 49 |
Hi I have a 125T chart I am used to having an indicator on the chart that is based on the 500T How do I do that Thanks |
[2015-05-26 20:04:42] |
Refer to help topic 28: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-26 20:51:37] |
Hi I followed teh instructions I have a 125T and 500T I will hide the 500T but I want to keep the bollinger sq based on the 500T At the moment it lokks wierd and not like the same on a separate 500T chart I have up, any wy around this? Thanks |
