Date/Time: Sun, 22 Dec 2024 19:14:12 +0000
CAN FILTRER MARKET ORDERS NUMBERS BARS?
View Count: 872
[2015-05-26 10:58:50] |
User469041 - Posts: 4 |
Hi, Can filter market orders in the numbers bars (footprint) eg see that the market order above 100 "lift the offer" "take the offers" Regard, |
[2015-05-26 12:44:31] |
Yes. Follow the instructions here to set Volume Filtering: http://www.sierrachart.com/index.php?page=doc/doc_NumbersBars.php#VolumeFiltering Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-26 20:42:21] |
I tried but it does not work! can you give me an example. with my thanks
[2015-05-26 21:16:30] |
What did you set the Volume Filter settings to?
[2015-05-27 08:39:09] |
I'll do a test, I'll let you know.
