Date/Time: Mon, 21 Sep 2026 07:11:21 +0000
alert email from acsil
View Count: 1998
[2015-05-26 10:36:09]
User53496 - Posts: 34
I am trying to send an email from acsil.
Followed the instructions and defined:
1. in General Settings, Alerts: Defined Alert1 to send an email and set address
2. in General Trade Settings defined "Play alert when order fills" to Alert1
Now in the code i use sc.SetAlert(1, "xyz")
but in alerts log after replay I see "no alert sound/email"
so what am I doing wrong??
regards, Eyal.
[2015-05-26 13:31:23]
Do you mean you do not see an alert message or line in the Alerts Log added after calling that function? If so, then this means the function call was ignored. Refer to the documentation for more information.
Date Time Of Last Edit: 2015-05-26 13:31:42
[2015-05-26 13:54:28]
I do see a line in the alert manager, with all the details in alert text column and "formula:xyz",
but in the end of this line it said: "No alert sound/email"
so it means the function was called and parameters were passed, but something in the definitions of alert1 maybe was wrong?
[2015-05-28 05:03:18]
We have looked into this and we have determined this occurs during a back test. There will not be alert sounds or emails during a back test.
We will update the documentation to explain this.
[2015-05-28 07:13:06]
Great. So it works in live? In the mean time I used "sc.PlaySoundA" and it does work on back test.
My guess is that generally alerts should not work on back test because it can cause sending too many emails at once.
[2015-05-28 07:19:12]
Yes it will work when not running a back test.
