Date/Time: Sun, 22 Dec 2024 14:47:51 +0000
CFD trading with IB
View Count: 2406
[2015-05-26 08:05:35] |
User17477 - Posts: 65 |
Hi, I am setting SC up for CFD trading with IB. I see from the example of your IB symbols page that the DE30 is IBDE30-CFD-SMART-EUR-BAAVG. I also want to set up the US500, FTSE100 and EURO 50. Do you please know the full code for these for Sierra Chart? thanks |
[2015-05-26 13:12:43] |
The different parts of a symbol used in Sierra Chart for Interactive Brokers are defined by Interactive Brokers except for the -BAAVG suffix. So contact IB to find out what the first part of the complete symbol should be for these. We do not know.
[2015-05-27 16:35:54] |
IB Hello, this is ‘xxxxx. How may I help you? Me: hi, i need the full symbol for the ibus500 for Sierra Chart please. IB unfortunately we do not have the symbology for Sierra Charts IB you will have to get that from them Me: for example, ibeu50-cfd-smart-eur-baavg works foe ibeu50 IB Different third party applications use their own symbols for populating data Me: no, they said you will give them Me: please help me IB We have the sybmbols for what will work in TWS IB if yu type in IBUS500 you will get the US 500 IBCFD contract IB Sierra charts is not our program we will not have that information Can you help me? |
[2015-05-27 17:27:03] |
Based on the above the symbol will be: IBUS500-CFD-SMART-USD-BAAVG Also the way to ask this question is to not mention Sierra Chart but to ask them what symbol is used within Trader Workstation. Once you know that symbol and the currency, you can determine the symbol for Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-27 17:27:35
[2015-05-28 22:05:36] |
I now have the chart open. What are the settings for the Sierra Chart DOM in terms of tick sizing etc? Am I ok to use the DOM for trading these CFDs? cheers |
[2015-05-29 03:14:54] |
Usually the tick size should be set correctly for the CFD from data provided by Interactive Brokers TWS. Otherwise, we would not know what they should be.
[2015-05-29 16:37:56] |
The tick size was too granular by default (0.01)with the DOM moving up and down the screen with every small move. For anyone else reading this I set it at .25 and it is much easier to work with.
