Date/Time: Sun, 22 Dec 2024 19:04:11 +0000
Change Study #
View Count: 890
[2015-05-25 19:28:49]
rhovega - Posts: 279
Is it possible to modify the assigned study ID numbers? If not, is that something you would consider implementing? It would be very convenient for writing signals when using alert studies (not spreadsheet alerts)
For example, say on one chart a MACD study is showing as ID20, while on another chart the same MACD study is showing as ID42. For writing formulas/conditions across multiple charts, it would be convenient if the user could modify the study ID number (to make them match). Otherwise one is forced to write different conditions for different charts. I trading multiple instruments it can be quite consuming.
