Date/Time: Sun, 22 Dec 2024 19:39:15 +0000
source for RWI
View Count: 883
[2015-05-25 15:26:53]
User911705 - Posts: 89
I'm attempting to work out a variation in the way the RWI indicator is coded between Sierra and other platforms. I think I checked every available source doc .cpp available in the Source folder but could only find the RWI study interface, not the code for the actual computation. Perhaps I missed it.
Would it be possible to get this? I'm sort of lost without it. To the best of my ability to check a couple simple cases (using a 2 period RWI) it seems like Sierra is not calculating according to what I've found in numerous online resources. I can provide an example if you want, but it's probably far easier for all concerned if you were able to provide the .cpp source.
Thank you.
EDIT: never mind, found what I was looking for. If I can't figure out what's going on I'll post a specific example calculation.
Date Time Of Last Edit: 2015-05-25 18:34:31
[2015-05-25 20:17:54]
This code exists in /ACS_Source/SCStudyFunctions.cpp
The function name is RWI_S
