Date/Time: Mon, 05 Oct 2026 21:33:50 +0000
Problem with Font
View Count: 1362
[2015-05-25 14:29:09]
chris12 - Posts: 53
hi SC
I have version 1243, when i download an older version, i have problem with the font of few charts like the picture joined…
when i go in Graphic settings --> fonts-->chart text, select --> it appear there is a problem.
Date Time Of Last Edit: 2015-05-25 20:15:18
imageCapture d’écran 2015-05-25 à 15.32.36.png / V - Attached On 2015-05-25 14:26:27 UTC - Size: 22.17 KB - 509 views
[2015-05-25 20:14:27]
Do you see this problem on the current version of Sierra Chart, 1258?
[2015-05-26 11:38:44]
chris12 - Posts: 53
yes absolutely
[2015-05-26 12:25:17]
Can you provide us a screenshot of what you see when you select Global Settings >> Graphics Settings >> Fonts >> Select.
[2015-05-26 14:26:36]
chris12 - Posts: 53
the picture joined
note that it's written in my language in French…
"no font installed.
Open the file font in the control panel to install a font"
some graph appear normal, other not...
imageCapture d’écran 2015-05-26 à 15.43.10.png / V - Attached On 2015-05-26 13:44:23 UTC - Size: 26.6 KB - 512 views
[2015-05-27 05:29:57]
Could you update Sierra Chart by selecting Help >> Download Current Version.
Let us know if you continue to see this problem after the update. We made a change that might help.
[2015-05-27 11:36:09]
chris12 - Posts: 53
ok some of charts appear always with the font "weddings" but i can change it NOW in using the way : chart -->graphic settings-->fonts
Note that if i use global settings-->graphics settings-->fonts : it doesn't change anything
thx
[2015-05-27 18:12:47]
This would mean the chart is set to use its own Graphics Settings. This is explained here:
Graphics Settings
