Date/Time: Mon, 14 Sep 2026 16:20:54 +0000
Weekend data
View Count: 1367
[2015-05-25 06:29:15]
User11942 - Posts: 298
Hello SC, my charts have non-existent weekend data and those bars can't be removed with conventional tools (re-downloading etc). All futures symbols are affected. I attached screenshots herein. Please clean the data up. Thanks.
imageF.US.TFEm15 10 Min #1 2015-05-25 02_18_21.093.png / V - Attached On 2015-05-25 06:24:17 UTC - Size: 37.86 KB - 520 views
imageF.US.USAM15 10 Min #1 2015-05-25 02_18_39.439.png / V - Attached On 2015-05-25 06:24:21 UTC - Size: 49.64 KB - 502 views
[2015-05-25 07:48:58]
This was a problem on the CQG side. They were transmitting trade data while the markets were closed.
The historical database has been cleaned up.
[2015-05-25 08:23:28]
Thanks for swift resolution. Yes, I know that they do it almost every time. That problem with data transmission during weekends persisted for some time in the past until you fixed it somehow. And most likely its going to happen today while markets are halted during 1:00 PM-6:00 PM window (Eastern). Wouldn't it be easier for you to set up a permanent fix again?
[2015-05-25 08:28:29]
Let us know what you see when the markets are closed today.
Date Time Of Last Edit: 2015-05-25 08:32:08
[2015-05-25 21:45:40]
Hello SC team, I see the same problem. What's interesting that the problem appeared only after re-connection to the trading service (I restarted the application). Thanks.
imageF.US.EPM15 10 Min #1 2015-05-25 17_31_16.704.png / V - Attached On 2015-05-25 21:36:14 UTC - Size: 64.97 KB - 495 views
imageF.US.USAM15 10 Min #1 2015-05-25 17_32_32.464.png / V - Attached On 2015-05-25 21:36:19 UTC - Size: 71.24 KB - 487 views
[2015-05-26 05:02:35]
We have told CQG about this. Only they can solve this kind of problem.
We have cleaned up the database.
