Date/Time: Thu, 24 Sep 2026 06:09:43 +0000
get the price in SG format with the number bars study
View Count: 1338
| [2015-05-24 17:08:07] |
| nioko54130 - Posts: 108 |
Hello dear support, in the "numbers bars" study, we could make appear the "price" displayed for each tick of a range bar by setting "price" in the "column number bar text". How could i do to get this information in "SG format" ? I ask you that to be able to make few calculation where the price is important in the formula of these calculation with the study subgraph (multiply, divide, sum, etc) thank's Date Time Of Last Edit: 2015-05-24 17:08:40
| [2015-05-26 06:22:59] |
This data is not accessible through Study Subgraphs.
| [2015-05-26 06:42:53] |
oh ok, do you know if there is an other studie where i could find this data (price displayed for each tick) ? Thank's ! |
| [2015-05-28 03:31:44] |
No. You have to create your own custom study to access this data.
