Date/Time: Sun, 22 Dec 2024 19:41:38 +0000
fractal
View Count: 935
[2015-05-24 00:57:26] |
User705641 - Posts: 38 |
Is there any way of showing fractal points on the active chart 1 area - rather than a separate indicator ( eg the williams fractal indicator )
[2015-05-24 06:42:02] |
Yes. If you are referring to the Bill Williams Fractals study, it does appear in Chart Region1. So it does not for you?
