Date/Time: Thu, 10 Sep 2026 06:55:28 +0000
[User Discussion] - This possible? Weekly average from historic daily data. Or 5m average from all trades.
View Count: 1323
| [2015-05-24 00:41:57] |
| esMike - Posts: 83 |
I know this might be a little computationally intensive, but is it possible to get the data for the average of all trades during a time period, or the average of all data for a time period? For example, displaying the mid point of a 5m bar based upon the average of all trades during that bar. Or, displaying the average of a weekly bar based upon the average of all daily OHLC data. I know how to do it manually by say taking a 1m chart and feeding the data over to a 5m chart, but it's kind of a "hacky" workaround... |
| [2015-05-26 06:16:38] |
Really what you have described as currently your solution is the proper way to do this. There is not another way.
| [2015-05-27 02:15:51] |
| StevieD - Posts: 39 |
Just throwing this out... The Auto Retracement/Projection study. Set the time period settings etc. Create a .5 level. Make all other levels (not the .5 level) and drawings hidden. ez pz. You could also use a MA study. Choose OHLC Avg as input data with a period of 1. Slightly diff result than Auto Retrace/Project, but again ez pz. All depends on the precision wanted/needed. Good trading. |
