Date/Time: Sun, 22 Dec 2024 11:05:39 +0000
Bollinger Bands
View Count: 1435
[2015-05-22 21:50:36] |
User95521 - Posts: 53 |
Hi, Is our formula of Bollinger Bands the same with MT4 terminal? I use the same setting but get different result. It looks MT4 version is better... Could you please tell me how to adjust it to get the same result with MT4? Thank you! Regards! |
[2015-05-22 23:12:21] |
We do not know if it is the same but Sierra Chart does calculate Bollinger Bands in a proper way. Since we do not know how MT4 terminal calculates it, we do not know what settings need to be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-22 23:12:43
[2015-05-23 00:10:46] |
Hi, Thank you very much for your replying. You could see the charts below, they do seems have some difference between each other, especially in longer timeframe. If I got the code of Bollinger Bands in MT4, could you please help me to translate it into Sierrachart study? If possible, I am willing to pay additional fees for the translation. Thank you! Best Regards! |
Private File Private File Private File Private File Private File Private File |
[2015-05-23 03:56:18] |
If you are willing to pay for the translation, then provide us the code.
[2015-05-23 04:19:58] |
OK, Thank you very much for your help! I'll tell my friend to get the ex4 file to mql4 code and then attach it here. Thank you! Have a great wekend! |
[2015-06-02 06:37:03] |
Hi, I apologize for the delay. My friend also failed to find it in the new version of MT4. He told me Bollinger Bands was hided in this file. Does it could be translated into sierrachart study? Thank you! Best Regards! |
[2015-06-04 00:45:25] |
Really what we need is a plain text description of how the calculation should be done. We have looked at these files and they are not useful for us.
[2015-06-05 15:01:34] |
Hi, I apologize for making so much trouble to you. I know nothing about MQL4 code... This file a located in the custom indicators of MT4. It shows the same result with Bollinger bands. If possible, could you please have a look on it? Will it have some help in the translation? Thank you! Best Regards! |
Private File |
[2015-06-12 03:40:05] |
We have had a look at this formula. And we think we understand it. We are going to add a new study to the next release named: BollingerBands - StandardDeviationOfAverage Let us know if it does what you want. The cost will be 25 USD. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-06-15 10:35:52
[2015-06-15 10:02:33] |
Hi, I apologize to reply so late. My son was in Hos and I did not check my mail these days. Ok, no problem, my account balance is exactly enough to the payment. Please reduce it directly. In addition, in the new "BollingerBands - StandardDeviationOfAverage" study, could you please retain the options of "Ma period, shift, MA method and Apply to"? (Please see the chart below) Also, If there is still a long time before the next version release, also if possible, could you please send me the mew indicator when you finished it? It is very useful to me. Thank you again for your help! Have a great day! |
[2015-06-15 20:12:03] |
The new release will be out today. All of the Inputs and options you are looking for are supported in the new study.
[2015-06-15 20:39:26] |
OK,I'll wait for it. Thank you very much for your help! Cheers! |
