Date/Time: Sun, 22 Dec 2024 19:19:35 +0000
OEC ZNM5 Symbol not updating
View Count: 1008
[2015-05-22 17:23:50] |
dennismed - Posts: 62 |
the symbols for treasuries is not providing live data is the an issue or is it my data feed from OEC
[2015-05-22 17:33:44] |
Provide a copy of the Message Log, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-22 22:36:02] |
Software version: 1227 | 2015-05-22 08:17:32 Uses New Spreadsheets | 2015-05-22 08:17:32 Usage end date: 2015-05-25 | 2015-05-22 08:17:32 Enabled for: Advanced Features. | 2015-05-22 08:17:32 Enabled for: Advanced Features 2. | 2015-05-22 08:17:32 Enabled for: Sierra Chart Historical Data Service. | 2015-05-22 08:17:32 Allow Support for Sierra Chart Data Feeds is enabled. | 2015-05-22 08:17:32 Active service: Open E Cry FIX | 2015-05-22 08:17:32 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2015-05-22 08:17:32 2015-05-22 08:17:32 Local computer clock time | 2015-05-22 08:17:32 2015-05-22 12:17:32 GMT time | 2015-05-22 08:17:32 2015-05-22 08:17:32 Time zone adjusted time | 2015-05-22 08:17:32 Time difference to server time: 3 seconds. | 2015-05-22 08:17:32 Program path: C:\SierraChart\ | 2015-05-22 08:17:32 Data Files path: C:\SierraChart\Data\ | 2015-05-22 08:17:32 OS Version Number: 6.1 | 2015-05-22 08:17:32 Locale Information: C | 2015-05-22 08:17:32 Checking for new symbol settings for oec | 2015-05-22 08:17:33 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2015-05-22 08:17:33 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2015-05-22 08:17:33 Notice: 3 days of full use remaining. To continue full use the software and services, | 2015-05-22 08:17:33 purchase more usage time by selecting 'Help >> Add Usage Credit' on the menu. | 2015-05-22 08:17:33 * Symbol settings are up-to-date for oec | 2015-05-22 08:17:33 Open E Cry FIX | Connecting to trading server prod.openecry.com:9400. | 2015-05-22 08:17:38 OEC FIX Trading socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-05-22 08:17:38 OEC FIX Trading socket (2) | Connected. | 2015-05-22 08:17:38 OEC FIX Trading socket (2) | Starting SSL connection. | 2015-05-22 08:17:38 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2015-05-22 08:17:39 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2015-05-22 08:17:39 OEC FIX Trading socket (2) | SSL connection established. | 2015-05-22 08:17:39 OEC FIX Trading: Sending the Logon message. | 2015-05-22 08:17:39 OEC FIX Trading | Connected to trading server. | 2015-05-22 08:17:39 Open E Cry FIX | Connecting to market data server prod.openecry.com:9301. | 2015-05-22 08:17:39 OEC FAST Data socket (0) | Resolved address prod.openecry.com to IP 64.94.37.206 | 2015-05-22 08:17:39 OEC FAST Data socket (3) | Connected. | 2015-05-22 08:17:39 OEC FAST Data: Sending the Hello message. | 2015-05-22 08:17:39 OEC FAST Data: Sending the Logon message. | 2015-05-22 08:17:39 Open E Cry FIX | Connected to the market data server. | 2015-05-22 08:17:39 Open E Cry FIX | Connected. | 2015-05-22 08:17:39 Open E Cry FIX: Received Trade Positions request acknowledgment message. Request Result: 2. Request Status: 1 | 2015-05-22 08:17:54 NVOL-SP [CV] 15 Min #36: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-05-22 08:22:26 NVOL-SP [CV] 15 Min #36: There are no continuous futures contract symbols. Loading data normally. | 2015-05-22 08:22:26 Date rule based rollover from ESM3 to next contract occurs at 2013-06-13. | 2015-05-22 08:22:26 Date rule based rollover from ESU3 to next contract occurs at 2013-09-12. | 2015-05-22 08:22:26 Date rule based rollover from ESZ3 to next contract occurs at 2013-12-12. | 2015-05-22 08:22:26 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-05-22 08:22:26 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-05-22 08:22:26 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-05-22 08:22:26 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-05-22 08:22:26 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-05-22 08:22:26 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-05-22 08:22:26 Intraday data file for ESM3 exists and is empty. Skipping Intraday data download. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESU3 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESZ3 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:26 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-05-22 08:22:26 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:22:26 Performing historical Daily data download for symbol ESM15 starting at 0. | 2015-05-22 08:22:26 ESM5 [CV] 1 Day #8 | Symbols used for continuous contract chart: | 2015-05-22 08:22:26 ESM3 | 2015-05-22 08:22:26 ESU3 | 2015-05-22 08:22:26 ESZ3 | 2015-05-22 08:22:26 ESH4 | 2015-05-22 08:22:26 ESM4 | 2015-05-22 08:22:26 ESU4 | 2015-05-22 08:22:26 ESZ4 | 2015-05-22 08:22:26 ESH5 | 2015-05-22 08:22:26 ESM5 | 2015-05-22 08:22:26 ESM5 [CV] 1 Day #8 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-22 08:22:26 NVOL-SP [CV] 5 Min #42: No contract months found for symbol. Unable to build continuous futures contract chart. | 2015-05-22 08:22:27 NVOL-SP [CV] 5 Min #42: There are no continuous futures contract symbols. Loading data normally. | 2015-05-22 08:22:27 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-22 08:22:27 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-22 08:22:27 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-22 08:22:27 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-22 08:22:27 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-22 08:22:27 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-22 08:22:27 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-22 08:22:27 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-22 08:22:27 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-22 08:22:27 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-22 08:22:27 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-22 08:22:27 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-22 08:22:27 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:27 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:22:27 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-22 08:22:27 ESM15/ESM5 [CV] Daily #15 | Symbols used for continuous contract chart: | 2015-05-22 08:22:27 ESM12 | 2015-05-22 08:22:27 ESU12 | 2015-05-22 08:22:27 ESZ12 | 2015-05-22 08:22:27 ESH13 | 2015-05-22 08:22:27 ESM13 | 2015-05-22 08:22:27 ESU13 | 2015-05-22 08:22:27 ESZ13 | 2015-05-22 08:22:27 ESH14 | 2015-05-22 08:22:27 ESM14 | 2015-05-22 08:22:27 ESU14 | 2015-05-22 08:22:27 ESZ14 | 2015-05-22 08:22:27 ESH15 | 2015-05-22 08:22:27 ESM15 | 2015-05-22 08:22:27 ESM15/ESM5 [CV] Daily #15 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-22 08:22:27 Date rule based rollover from ESM3 to next contract occurs at 2013-06-13. | 2015-05-22 08:22:48 Date rule based rollover from ESU3 to next contract occurs at 2013-09-12. | 2015-05-22 08:22:48 Date rule based rollover from ESZ3 to next contract occurs at 2013-12-12. | 2015-05-22 08:22:48 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-05-22 08:22:48 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-05-22 08:22:48 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-05-22 08:22:48 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-05-22 08:22:48 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-05-22 08:22:48 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-05-22 08:22:48 Intraday data file for ESM3 exists and is empty. Skipping Intraday data download. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESU3 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESZ3 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:48 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:48 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-05-22 08:22:51 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:22:51 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37 | Symbols used for continuous contract chart: | 2015-05-22 08:22:51 ESM3 | 2015-05-22 08:22:51 ESU3 | 2015-05-22 08:22:51 ESZ3 | 2015-05-22 08:22:51 ESH4 | 2015-05-22 08:22:51 ESM4 | 2015-05-22 08:22:51 ESU4 | 2015-05-22 08:22:51 ESZ4 | 2015-05-22 08:22:51 ESH5 | 2015-05-22 08:22:51 ESM5 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Checking for volume based rollover dates. | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESM3 to ESU3 occurs at 2013-06-14 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESU3 to ESZ3 occurs at 2013-09-13 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESZ3 to ESH4 occurs at 2013-12-13 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESH4 to ESM4 occurs at 2014-03-14 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESM4 to ESU4 occurs at 2014-06-12 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESU4 to ESZ4 occurs at 2014-09-12 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESZ4 to ESH5 occurs at 2014-12-12 | 2015-05-22 08:22:51 ESM5 [CV] 1 Day #37: Volume based rollover from ESH5 to ESM5 occurs at 2015-03-13 | 2015-05-22 08:22:51 Date rule based rollover from ESZ06 to next contract occurs at 2006-12-07. | 2015-05-22 08:22:52 Date rule based rollover from ESH07 to next contract occurs at 2007-03-08. | 2015-05-22 08:22:52 Date rule based rollover from ESM07 to next contract occurs at 2007-06-07. | 2015-05-22 08:22:52 Date rule based rollover from ESU07 to next contract occurs at 2007-09-13. | 2015-05-22 08:22:52 Date rule based rollover from ESZ07 to next contract occurs at 2007-12-13. | 2015-05-22 08:22:52 Date rule based rollover from ESH08 to next contract occurs at 2008-03-13. | 2015-05-22 08:22:52 Date rule based rollover from ESM08 to next contract occurs at 2008-06-12. | 2015-05-22 08:22:52 Date rule based rollover from ESU08 to next contract occurs at 2008-09-11. | 2015-05-22 08:22:52 Date rule based rollover from ESZ08 to next contract occurs at 2008-12-11. | 2015-05-22 08:22:52 Date rule based rollover from ESH09 to next contract occurs at 2009-03-12. | 2015-05-22 08:22:52 Date rule based rollover from ESM09 to next contract occurs at 2009-06-11. | 2015-05-22 08:22:52 Date rule based rollover from ESU09 to next contract occurs at 2009-09-10. | 2015-05-22 08:22:52 Date rule based rollover from ESZ09 to next contract occurs at 2009-12-10. | 2015-05-22 08:22:52 Date rule based rollover from ESH10 to next contract occurs at 2010-03-11. | 2015-05-22 08:22:52 Date rule based rollover from ESM10 to next contract occurs at 2010-06-10. | 2015-05-22 08:22:52 Date rule based rollover from ESU10 to next contract occurs at 2010-09-09. | 2015-05-22 08:22:52 Date rule based rollover from ESZ10 to next contract occurs at 2010-12-09. | 2015-05-22 08:22:52 Date rule based rollover from ESH11 to next contract occurs at 2011-03-10. | 2015-05-22 08:22:52 Date rule based rollover from ESM11 to next contract occurs at 2011-06-09. | 2015-05-22 08:22:52 Date rule based rollover from ESU11 to next contract occurs at 2011-09-08. | 2015-05-22 08:22:52 Date rule based rollover from ESZ11 to next contract occurs at 2011-12-08. | 2015-05-22 08:22:52 Date rule based rollover from ESH12 to next contract occurs at 2012-03-08. | 2015-05-22 08:22:52 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-22 08:22:52 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-22 08:22:52 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-22 08:22:52 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-22 08:22:52 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-22 08:22:52 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-22 08:22:52 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-22 08:22:52 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-22 08:22:52 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-22 08:22:52 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-22 08:22:52 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-22 08:22:52 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-22 08:22:52 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-22 08:22:52 Checking Daily data file for symbol ESZ06 for the date range from 2006-09-07 to 2006-12-07. | 2015-05-22 08:22:52 Checking Daily data file for symbol ESH07 for the date range from 2006-12-07 to 2007-03-08. | 2015-05-22 08:22:53 Checking Daily data file for symbol ESM07 for the date range from 2007-03-08 to 2007-06-07. | 2015-05-22 08:22:53 Checking Daily data file for symbol ESU07 for the date range from 2007-06-07 to 2007-09-13. | 2015-05-22 08:22:54 Checking Daily data file for symbol ESZ07 for the date range from 2007-09-13 to 2007-12-13. | 2015-05-22 08:22:54 Checking Daily data file for symbol ESH08 for the date range from 2007-12-13 to 2008-03-13. | 2015-05-22 08:22:54 Checking Daily data file for symbol ESM08 for the date range from 2008-03-13 to 2008-06-12. | 2015-05-22 08:22:54 Checking Daily data file for symbol ESU08 for the date range from 2008-06-12 to 2008-09-11. | 2015-05-22 08:22:54 Checking Daily data file for symbol ESZ08 for the date range from 2008-09-11 to 2008-12-11. | 2015-05-22 08:22:55 Checking Daily data file for symbol ESH09 for the date range from 2008-12-11 to 2009-03-12. | 2015-05-22 08:22:56 Checking Daily data file for symbol ESM09 for the date range from 2009-03-12 to 2009-06-11. | 2015-05-22 08:22:56 Checking Daily data file for symbol ESU09 for the date range from 2009-06-11 to 2009-09-10. | 2015-05-22 08:22:56 Checking Daily data file for symbol ESZ09 for the date range from 2009-09-10 to 2009-12-10. | 2015-05-22 08:22:56 Checking Daily data file for symbol ESH10 for the date range from 2009-12-10 to 2010-03-11. | 2015-05-22 08:22:56 Checking Daily data file for symbol ESM10 for the date range from 2010-03-11 to 2010-06-10. | 2015-05-22 08:22:57 Checking Daily data file for symbol ESU10 for the date range from 2010-06-10 to 2010-09-09. | 2015-05-22 08:22:57 Checking Daily data file for symbol ESZ10 for the date range from 2010-09-09 to 2010-12-09. | 2015-05-22 08:22:57 Checking Daily data file for symbol ESH11 for the date range from 2010-12-09 to 2011-03-10. | 2015-05-22 08:22:57 Checking Daily data file for symbol ESM11 for the date range from 2011-03-10 to 2011-06-09. | 2015-05-22 08:22:57 Checking Daily data file for symbol ESU11 for the date range from 2011-06-09 to 2011-09-08. | 2015-05-22 08:22:58 Checking Daily data file for symbol ESZ11 for the date range from 2011-09-08 to 2011-12-08. | 2015-05-22 08:22:58 Checking Daily data file for symbol ESH12 for the date range from 2011-12-08 to 2012-03-08. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:22:59 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-22 08:22:59 ESM15/ESM5 [CBV] Monthly #38 | Symbols used for continuous contract chart: | 2015-05-22 08:22:59 ESZ06 | 2015-05-22 08:22:59 ESH07 | 2015-05-22 08:22:59 ESM07 | 2015-05-22 08:22:59 ESU07 | 2015-05-22 08:22:59 ESZ07 | 2015-05-22 08:22:59 ESH08 | 2015-05-22 08:22:59 ESM08 | 2015-05-22 08:22:59 ESU08 | 2015-05-22 08:22:59 ESZ08 | 2015-05-22 08:22:59 ESH09 | 2015-05-22 08:22:59 ESM09 | 2015-05-22 08:22:59 ESU09 | 2015-05-22 08:22:59 ESZ09 | 2015-05-22 08:22:59 ESH10 | 2015-05-22 08:22:59 ESM10 | 2015-05-22 08:22:59 ESU10 | 2015-05-22 08:22:59 ESZ10 | 2015-05-22 08:22:59 ESH11 | 2015-05-22 08:22:59 ESM11 | 2015-05-22 08:22:59 ESU11 | 2015-05-22 08:22:59 ESZ11 | 2015-05-22 08:22:59 ESH12 | 2015-05-22 08:22:59 ESM12 | 2015-05-22 08:22:59 ESU12 | 2015-05-22 08:22:59 ESZ12 | 2015-05-22 08:22:59 ESH13 | 2015-05-22 08:22:59 ESM13 | 2015-05-22 08:22:59 ESU13 | 2015-05-22 08:22:59 ESZ13 | 2015-05-22 08:22:59 ESH14 | 2015-05-22 08:22:59 ESM14 | 2015-05-22 08:22:59 ESU14 | 2015-05-22 08:22:59 ESZ14 | 2015-05-22 08:22:59 ESH15 | 2015-05-22 08:22:59 ESM15 | 2015-05-22 08:22:59 ESM15/ESM5 [CBV] Monthly #38 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-22 08:22:59 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-22 08:22:59 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-22 08:22:59 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-22 08:22:59 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-22 08:22:59 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-22 08:22:59 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-22 08:22:59 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-22 08:22:59 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-22 08:22:59 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-22 08:22:59 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-22 08:22:59 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-22 08:22:59 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-22 08:22:59 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:22:59 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:22:59 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-22 08:22:59 ESM15/ESM5 [CV] Weekly #44 | Symbols used for continuous contract chart: | 2015-05-22 08:22:59 ESM12 | 2015-05-22 08:22:59 ESU12 | 2015-05-22 08:22:59 ESZ12 | 2015-05-22 08:22:59 ESH13 | 2015-05-22 08:22:59 ESM13 | 2015-05-22 08:22:59 ESU13 | 2015-05-22 08:22:59 ESZ13 | 2015-05-22 08:22:59 ESH14 | 2015-05-22 08:22:59 ESM14 | 2015-05-22 08:22:59 ESU14 | 2015-05-22 08:22:59 ESZ14 | 2015-05-22 08:22:59 ESH15 | 2015-05-22 08:22:59 ESM15 | 2015-05-22 08:22:59 ESM15/ESM5 [CV] Weekly #44 | Waiting for historical downloads to complete with the IDs: 1, | 2015-05-22 08:22:59 Date rule based rollover from ESM3 to next contract occurs at 2013-06-13. | 2015-05-22 08:23:05 Date rule based rollover from ESU3 to next contract occurs at 2013-09-12. | 2015-05-22 08:23:05 Date rule based rollover from ESZ3 to next contract occurs at 2013-12-12. | 2015-05-22 08:23:05 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13. | 2015-05-22 08:23:05 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12. | 2015-05-22 08:23:05 Date rule based rollover from ESU4 to next contract occurs at 2014-09-11. | 2015-05-22 08:23:05 Date rule based rollover from ESZ4 to next contract occurs at 2014-12-11. | 2015-05-22 08:23:05 Date rule based rollover from ESH5 to next contract occurs at 2015-03-12. | 2015-05-22 08:23:05 Date rule based rollover from ESM5 to next contract occurs at 2015-06-11. | 2015-05-22 08:23:05 Intraday data file for ESM3 exists and is empty. Skipping Intraday data download. | 2015-05-22 08:23:05 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:23:05 Checking Intraday data file for symbol ESU3 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESZ3 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESM4 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESU4 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESZ4 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESH5 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:23:06 Checking Intraday data file for symbol ESM5 for the date range from 2015-03-12 to 0. | 2015-05-22 08:23:06 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:23:08 Skipping Daily data download for symbol ESM15 since download was already done in last 24 hours. | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40 | Symbols used for continuous contract chart: | 2015-05-22 08:23:08 ESM3 | 2015-05-22 08:23:08 ESU3 | 2015-05-22 08:23:08 ESZ3 | 2015-05-22 08:23:08 ESH4 | 2015-05-22 08:23:08 ESM4 | 2015-05-22 08:23:08 ESU4 | 2015-05-22 08:23:08 ESZ4 | 2015-05-22 08:23:08 ESH5 | 2015-05-22 08:23:08 ESM5 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Checking for volume based rollover dates. | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESM3 to ESU3 occurs at 2013-06-14 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESU3 to ESZ3 occurs at 2013-09-13 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESZ3 to ESH4 occurs at 2013-12-13 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESH4 to ESM4 occurs at 2014-03-14 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESM4 to ESU4 occurs at 2014-06-12 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESU4 to ESZ4 occurs at 2014-09-12 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESZ4 to ESH5 occurs at 2014-12-12 | 2015-05-22 08:23:08 ESM5 [CV] 1 Day #40: Volume based rollover from ESH5 to ESM5 occurs at 2015-03-13 | 2015-05-22 08:23:08 HD Request # 2 | Downloading Historical Daily chart data for ESM15. Starting date: 2015-05-20. Service: oec | 2015-05-22 08:23:20 Historical data download counter reset. | 2015-05-22 08:23:20 HD Request # 2 | Requesting historical Daily data for ESM15 starting at 2015-05-19 | 2015-05-22 08:23:20 HD Request # 2 | Receiving historical Daily data for ESM15 starting at 2015-05-19 | 2015-05-22 08:23:21 Writing historical Daily data for ESM15 to the file ESM15.dly | 2015-05-22 08:23:21 HD Request # 2 | Received 4 records from 2015-05-19 00:00:00 to 2015-05-22 00:00:00 (4.0 days) and wrote 3 records for ESM15 | 2015-05-22 08:23:21 HD Request # 2 | Daily download COMPLETE for ESM15. Completion time: 1s. Unique request ID: 1 | 2015-05-22 08:23:21 Removed historical data download ID 1 | 2015-05-22 08:23:21 Open E Cry FIX | Starting real-time market data updates for: ESM5. ID: 2 | 2015-05-22 08:23:21 Intraday data recording state for symbol ESM5 is set to download pending. | 2015-05-22 08:23:21 HD Request # 3 | Downloading Intraday chart data for ESM5 to the file ESM5.scid. Service: oec | 2015-05-22 08:23:21 HD Request # 3 | Download start Date-Time: 2015-05-21 22:50:55.0 | 2015-05-22 08:23:24 HD Request # 3 | Using server: oec.sierracharts.com port 10149 | 2015-05-22 08:23:24 Socket (0) | Resolved address oec.sierracharts.com to IP 65.182.172.164 | 2015-05-22 08:23:24 Socket (4) | Connected. | 2015-05-22 08:23:24 HD Request # 3 | Sending historical data logon request message. | 2015-05-22 08:23:24 HD Request # 3 | Requesting Intraday data. Start Date-Time: 2015-05-21 22:50:55. Record interval: 0. Symbol: ESM5 | 2015-05-22 08:23:25 HD Request # 3 | Decompressing data. | 2015-05-22 08:23:25 HD Request # 3 | Receiving Intraday data for ESM5 starting at 2015-05-21 22:50:55 | 2015-05-22 08:23:25 HD Request # 3 | Timestamp of first Intraday data file record written: 2015-05-21 22:52:05 | 2015-05-22 08:23:25 SC Market Stats | Starting real-time market data updates for: NVOL-SP. ID: 3 | 2015-05-22 08:23:25 SC Market Stats | Connecting to the server ds5.sierracharts.com. Port 10048 | 2015-05-22 08:23:25 Intraday data recording state for symbol NVOL-SP is set to download pending. | 2015-05-22 08:23:25 Socket (4) | Shutdown and closed. | 2015-05-22 08:23:26 The network socket for historical data has been closed. | 2015-05-22 08:23:26 Socket (0) | Resolved address ds5.sierracharts.com to IP 204.15.192.106 | 2015-05-22 08:23:28 HD Request # 3 | Received 10182 records from 2015-05-21 22:50:55 to 2015-05-22 08:23:11 (9.5 hours) and wrote 10181 records for ESM5 | 2015-05-22 08:23:28 HD Request # 3 | Intraday download COMPLETE for ESM5. Completion time: 7s. Unique request ID: 2 | 2015-05-22 08:23:28 Removed historical data download ID 2 | 2015-05-22 08:23:28 Real-time Intraday chart data file updates started for ESM5 | 2015-05-22 08:23:28 Socket (5) | Connected. | 2015-05-22 08:23:28 SC Market Stats | Connected to server. | 2015-05-22 08:23:28 SC Market Stats | Sending logon request message. | 2015-05-22 08:23:28 HD Request # 4 | Downloading Intraday chart data for NVOL-SP to the file NVOL-SP.scid. Service: statscalc | 2015-05-22 08:23:28 HD Request # 4 | Download start Date-Time: 2015-05-21 19:59:59.0 | 2015-05-22 08:23:28 HD Request # 4 | Using server: ds3.sierracharts.com port 10149 | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Download is complete for all contract months in chart. Proceeding with data load. | 2015-05-22 08:23:28 Socket (0) | Resolved address ds3.sierracharts.com to IP 65.182.172.164 | 2015-05-22 08:23:28 Socket (6) | Connected. | 2015-05-22 08:23:28 HD Request # 4 | Sending historical data logon request message. | 2015-05-22 08:23:28 HD Request # 4 | Requesting Intraday data. Start Date-Time: 2015-05-21 19:59:59. Record interval: 0. Symbol: NVOL-SP | 2015-05-22 08:23:28 HD Request # 4 | Decompressing data. | 2015-05-22 08:23:28 HD Request # 4 | Receiving Intraday data for NVOL-SP starting at 2015-05-21 19:59:59 | 2015-05-22 08:23:28 HD Request # 4 | Timestamp of first Intraday data file record written: 2015-05-22 04:00:12 | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Checking for volume based rollover dates. | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Volume based rollover from ESM3 to ESU3 occurs at 2013-06-14 | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Volume based rollover from ESU3 to ESZ3 occurs at 2013-09-13 | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Volume based rollover from ESZ3 to ESH4 occurs at 2013-12-13 | 2015-05-22 08:23:28 ESM5 [CV] 1 Day #8: Volume based rollover from ESH4 to ESM4 occurs at 2014-03-14 | 2015-05-22 08:23:29 ESM5 [CV] 1 Day #8: Volume based rollover from ESM4 to ESU4 occurs at 2014-06-12 | 2015-05-22 08:23:29 ESM5 [CV] 1 Day #8: Volume based rollover from ESU4 to ESZ4 occurs at 2014-09-12 | 2015-05-22 08:23:29 ESM5 [CV] 1 Day #8: Volume based rollover from ESZ4 to ESH5 occurs at 2014-12-12 | 2015-05-22 08:23:29 ESM5 [CV] 1 Day #8: Volume based rollover from ESH5 to ESM5 occurs at 2015-03-13 | 2015-05-22 08:23:29 Socket (6) | Shutdown and closed. | 2015-05-22 08:23:29 The network socket for historical data has been closed. | 2015-05-22 08:23:29 SC Market Stats | Server Name: SC Real-Time Server. | 2015-05-22 08:23:30 SC Market Stats | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2015-05-22 08:23:30 SC Market Stats | Successfully connected. | 2015-05-22 08:23:30 SC Market Stats | Restarting real-time data updates for symbol: NVOL-SP | 2015-05-22 08:23:30 HD Request # 4 | Received 2103 records from 2015-05-21 19:59:59 to 2015-05-22 08:23:25 (12.4 hours) and wrote 2102 records for NVOL-SP | 2015-05-22 08:23:33 HD Request # 4 | Intraday download COMPLETE for NVOL-SP. Completion time: 5s. Unique request ID: 3 | 2015-05-22 08:23:33 Removed historical data download ID 3 | 2015-05-22 08:23:33 Real-time Intraday chart data file updates started for NVOL-SP | 2015-05-22 08:23:33 Open E Cry FIX | Starting real-time market data updates for: FESXM5. ID: 4 | 2015-05-22 08:23:35 Intraday data recording state for symbol FESXM5 is set to download pending. | 2015-05-22 08:23:35 HD Request # 5 | Downloading Intraday chart data for FESXM5 to the file FESXM5.scid. Service: oec | 2015-05-22 08:23:35 HD Request # 5 | Download start Date-Time: 2015-05-21 16:03:40.0 | 2015-05-22 08:23:35 HD Request # 5 | Using server: oec.sierracharts.com port 10149 | 2015-05-22 08:23:35 Socket (0) | Resolved address oec.sierracharts.com to IP 65.182.172.164 | 2015-05-22 08:23:35 Socket (7) | Connected. | 2015-05-22 08:23:35 HD Request # 5 | Sending historical data logon request message. | 2015-05-22 08:23:35 HD Request # 5 | Requesting Intraday data. Start Date-Time: 2015-05-21 16:03:40. Record interval: 0. Symbol: FESXM5 | 2015-05-22 08:23:35 HD Request # 5 | Decompressing data. | 2015-05-22 08:23:36 HD Request # 5 | Receiving Intraday data for FESXM5 starting at 2015-05-21 16:03:40 | 2015-05-22 08:23:36 HD Request # 5 | Timestamp of first Intraday data file record written: 2015-05-22 02:00:08 | 2015-05-22 08:23:36 Date rule based rollover from ESM12 to next contract occurs at 2012-06-07. | 2015-05-22 08:23:36 Date rule based rollover from ESU12 to next contract occurs at 2012-09-13. | 2015-05-22 08:23:36 Socket (7) | Shutdown and closed. | 2015-05-22 08:23:36 The network socket for historical data has been closed. | 2015-05-22 08:23:36 Date rule based rollover from ESZ12 to next contract occurs at 2012-12-13. | 2015-05-22 08:23:36 Date rule based rollover from ESH13 to next contract occurs at 2013-03-07. | 2015-05-22 08:23:36 Date rule based rollover from ESM13 to next contract occurs at 2013-06-13. | 2015-05-22 08:23:36 Date rule based rollover from ESU13 to next contract occurs at 2013-09-12. | 2015-05-22 08:23:36 Date rule based rollover from ESZ13 to next contract occurs at 2013-12-12. | 2015-05-22 08:23:36 Date rule based rollover from ESH14 to next contract occurs at 2014-03-13. | 2015-05-22 08:23:36 Date rule based rollover from ESM14 to next contract occurs at 2014-06-12. | 2015-05-22 08:23:36 Date rule based rollover from ESU14 to next contract occurs at 2014-09-11. | 2015-05-22 08:23:36 Date rule based rollover from ESZ14 to next contract occurs at 2014-12-11. | 2015-05-22 08:23:36 Date rule based rollover from ESH15 to next contract occurs at 2015-03-12. | 2015-05-22 08:23:36 Date rule based rollover from ESM15 to next contract occurs at 2015-06-11. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESM12 for the date range from 2012-03-08 to 2012-06-07. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESU12 for the date range from 2012-06-07 to 2012-09-13. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESZ12 for the date range from 2012-09-13 to 2012-12-13. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESH13 for the date range from 2012-12-13 to 2013-03-07. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESM13 for the date range from 2013-03-07 to 2013-06-13. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESU13 for the date range from 2013-06-13 to 2013-09-12. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESZ13 for the date range from 2013-09-12 to 2013-12-12. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESH14 for the date range from 2013-12-12 to 2014-03-13. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESM14 for the date range from 2014-03-13 to 2014-06-12. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESU14 for the date range from 2014-06-12 to 2014-09-11. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESZ14 for the date range from 2014-09-11 to 2014-12-11. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESH15 for the date range from 2014-12-11 to 2015-03-12. | 2015-05-22 08:23:36 Checking Daily data file for symbol ESM15 for the date range from 2015-03-12 to 2015-05-22. | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15 | Symbols used for continuous contract chart: | 2015-05-22 08:23:36 ESM12 | 2015-05-22 08:23:36 ESU12 | 2015-05-22 08:23:36 ESZ12 | 2015-05-22 08:23:36 ESH13 | 2015-05-22 08:23:36 ESM13 | 2015-05-22 08:23:36 ESU13 | 2015-05-22 08:23:36 ESZ13 | 2015-05-22 08:23:36 ESH14 | 2015-05-22 08:23:36 ESM14 | 2015-05-22 08:23:36 ESU14 | 2015-05-22 08:23:36 ESZ14 | 2015-05-22 08:23:36 ESH15 | 2015-05-22 08:23:36 ESM15 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Checking for volume based rollover dates. | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESM12 to ESU12 occurs at 2012-06-08 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESU12 to ESZ12 occurs at 2012-09-14 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESZ12 to ESH13 occurs at 2012-12-14 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESH13 to ESM13 occurs at 2013-03-08 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESM13 to ESU13 occurs at 2013-06-14 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESU13 to ESZ13 occurs at 2013-09-13 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESZ13 to ESH14 occurs at 2013-12-13 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESH14 to ESM14 occurs at 2014-03-14 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESM14 to ESU14 occurs at 2014-06-12 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESU14 to ESZ14 occurs at 2014-09-12 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESZ14 to ESH15 occurs at 2014-12-12 | 2015-05-22 08:23:36 ESM15/ESM5 [CV] Daily #15: Volume based rollover from ESH15 to ESM15 occurs at 2015-03-13 | 2015-05-22 08:23:36 HD Request # 5 | Received 18184 records from 2015-05-21 16:03:40 to 2015-05-22 08:23:27 (16.3 hours) and wrote 18183 records for FESXM5 | 2015-05-22 08:23:37 HD Request # 5 | Intraday download COMPLETE for FESXM5. Completion time: 2s. Unique request ID: 4 | 2015-05-22 08:23:37 Removed historical data download ID 4 | 2015-05-22 08:23:37 Real-time Intraday chart data file updates started for FESXM5 | 2015-05-22 08:23:37 SC Market Stats | Starting real-time market data updates for: DECL-NYSE. ID: 5 | 2015-05-22 08:23:38 Intraday data recording state for symbol DECL-NYSE is set to download pending. | 2015-05-22 08:23:38 HD Request # 6 | Downloading Intraday chart data for DECL-NYSE to the file DECL-NYSE.scid. Service: statscalc | 2015-05-22 08:23:38 HD Request # 6 | Download start Date-Time: 2015-05-21 19:59:59.0 | 2015-05-22 08:23:39 HD Request # 6 | Using server: ds4.sierracharts.com port 10149 | 2015-05-22 08:23:39 Socket (0) | Resolved address ds4.sierracharts.com to IP 204.11.49.26 | 2015-05-22 08:23:39 Socket (8) | Connected. | 2015-05-22 08:23:39 HD Request # 6 | Sending historical data logon request message. | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: ADV-NYSE. ID: 6 | 2015-05-22 08:23:39 Intraday data recording state for symbol ADV-NYSE is set to download pending. | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: NTCK-NASDAQ. ID: 7 | 2015-05-22 08:23:39 Intraday data recording state for symbol NTCK-NASDAQ is set to download pending. | 2015-05-22 08:23:39 Requesting market depth updates for: ESM5 if supported. | 2015-05-22 08:23:39 Requesting market depth updates for: FESXM5 if supported. | 2015-05-22 08:23:39 Open E Cry FIX | Starting real-time market data updates for: NQM5. ID: 8 | 2015-05-22 08:23:39 Requesting market depth updates for: NQM5 if supported. | 2015-05-22 08:23:39 Open E Cry FIX | Starting real-time market data updates for: RLM-MM5. ID: 9 | 2015-05-22 08:23:39 Requesting market depth updates for: RLM-MM5 if supported. | 2015-05-22 08:23:39 Open E Cry FIX | Starting real-time market data updates for: ZNM5. ID: 10 | 2015-05-22 08:23:39 Requesting market depth updates for: ZNM5 if supported. | 2015-05-22 08:23:39 HD Request # 6 | Requesting Intraday data. Start Date-Time: 2015-05-21 19:59:59. Record interval: 0. Symbol: DECL-NYSE | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: NTCK-YM. ID: 11 | 2015-05-22 08:23:39 Intraday data recording state for symbol NTCK-YM is set to download pending. | 2015-05-22 08:23:39 HD Request # 6 | Decompressing data. | 2015-05-22 08:23:39 HD Request # 6 | Receiving Intraday data for DECL-NYSE starting at 2015-05-21 19:59:59 | 2015-05-22 08:23:39 HD Request # 6 | Timestamp of first Intraday data file record written: 2015-05-22 04:00:12 | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: NTCK-TF. ID: 12 | 2015-05-22 08:23:39 Intraday data recording state for symbol NTCK-TF is set to download pending. | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: NTCK-SP. ID: 13 | 2015-05-22 08:23:39 Intraday data recording state for symbol NTCK-SP is set to download pending. | 2015-05-22 08:23:39 Socket (8) | Shutdown and closed. | 2015-05-22 08:23:39 The network socket for historical data has been closed. | 2015-05-22 08:23:39 SC Market Stats | Starting real-time market data updates for: TICK-NYSE. ID: 14 | 2015-05-22 08:23:41 Intraday data recording state for symbol TICK-NYSE is set to download pending. | 2015-05-22 08:23:41 HD Request # 6 | Received 2113 records from 2015-05-21 19:59:59 to 2015-05-22 08:23:36 (12.4 hours) and wrote 2112 records for DECL-NYSE | 2015-05-22 08:23:41 HD Request # 6 | Intraday download COMPLETE for DECL-NYSE. Completion time: 3s. Unique request ID: 5 | 2015-05-22 08:23:41 Removed historical data download ID 5 | 2015-05-22 08:23:41 Real-time Intraday chart data file updates started for DECL-NYSE | 2015-05-22 08:23:41 Symbol Error - ZNM5 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2015-05-22 08:23:42 Symbol Error - ZNM5 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2015-05-22 08:23:42 Symbol Error - ZNM5 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled | 2015-05-22 08:23:42 Date Time Of Last Edit: 2015-05-22 23:13:51
[2015-05-22 23:14:28] |
This is the relevant error message: Symbol Error - ZNM5 is unknown, unavailable, or improperly formatted. FIX reject reason: Data feed is not entitled Please contact OEC about this to have your account entitled to this exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
