Date/Time: Sun, 22 Dec 2024 19:56:23 +0000
[User Discussion] - E3 crossup B3 instead of E3>B3
View Count: 938
[2015-05-22 13:45:49] |
User81805 - Posts: 9 |
Right now I am working with strategies surrounding the formula: =AND(E3>B3) for long positions, but I want to have it so a Buy signal is created when E3 (last bar-value) cross up the B3 (open bar-value), instead of just having a buy signal created when E3>B3. How should this formula look like? |
[2015-05-22 14:23:01] |
Sawtooth - Posts: 4141 |
If your signal is at bar close, you'll need to reference the previous bar: =AND(B4>E4,E3>B3) You could also use: =CROSSFROMBELOW(E3:E4,B3:B4) If your signal is intrabar, this would be the formula: =E3>B3 and it would necessarily be the first occurrence in the current bar. Subsequent occurrences in the current bar could be eliminated with Signal Only Once Per Bar set to Yes. |
