Date/Time: Sat, 23 Nov 2024 00:26:29 +0000
[User Discussion] - Study/Price Overlay - 5 minute Chart (Vol by Price study) on 1 m
View Count: 1886
[2013-06-05 02:05:25] |
absorrel4 - Posts: 94 |
I am using the Study/Price Overlay to get the Vol by Price study from my 5 minute chart on my 1 minute chart (same symbol). But, the volume bars that show up on the 5 minute chart do not show up (at all) on the 1 minute chart. I have tried various scale options...but no luck. Any advice?
[2013-06-05 02:25:01] |
M5amhan - Posts: 468 |
what time frame is your volume profile set to?
[2013-06-05 02:45:34] |
Please see the attached image...
Vol By Price Settings.jpg / V - Attached On 2013-06-05 02:44:17 UTC - Size: 96.25 KB - 642 views |
[2013-06-05 02:48:55] |
No advice. This is not supported.
[2013-06-05 02:50:19] |
you can simply apply the same settings that you have in the image to your 1 minute chart and they will be the same profiles. volume profiles are not dependent on time frames unless you are using "visible bars" instead of "fixed by time" but you are not |
[2013-06-05 12:40:22] |
Trade2day1....thank you for the help. Learn something new everyday. SC Support...short and sweet answer but not very helpful. C'mon Man!!
