Date/Time: Mon, 16 Sep 2024 19:17:22 +0000
Spreadsheet System for Trading Test Procedure:
View Count: 1134
[2015-05-21 20:29:41] |
BataviaTrader - Posts: 63 |
I have run the Spreadsheet System for Trading Test Procedure you have build. It went wrong from point 17: "17. An order will have been submitted and the Trade Position will be established. You can confirm this by looking at cell J5. It will contain a nonzero value." In my case, cell J5 did not contain a nonzero value, it actually contained a zero. Afterwards I have checked the Trade Service Log. Below you find a copy. Apparently there is something wrong with the maximum order quantity. I find that however a bit strange as SC created this Test Procedure, I suppose including the default settings that come with it, such as order quantity. Could you advice what I do wrong and what I have to change? Thank you kindly in advance. --copy--> Trade Activity Log file read result: 1151 records inserted. 0 records filtered. | 2015-05-21 18:53:32 Trade Activity Log file date-time limits: Sim record date-time limit is 2015-02-10 00:00:00. Non-sim record date-time limit is 2015-02-10 00:00:00. Non-sim fill record date-time limit is 2014-07-25 00:00:00. | 2015-05-21 18:53:32 Interactive Brokers | Sent reqOpenOrders request | 2015-05-21 18:53:49 Cleared Trade Simulation Orders And Data. | 2015-05-21 19:31:33 Auto-Trading: Replay 60.0X: EURUSD 15 Min #1 | SpreadsheetTradeTest | BuyEntry signal is ignored because maximum Long Position quantity allowed has been reached or would be exceeded with new order. Max. Position allowed: 1000. Resulting Position without existing orders: 10000. Resulting Position with existing orders: 10000 | Bar Start Time: 2015-04-23 12:45:00 | 2015-05-21 19:46:10 Auto-Trading: Replay 60.0X: EURUSD 15 Min #1 | SpreadsheetTradeTest | BuyExit signal is ignored. Long position quantity does not exist or there are already working exit orders that will flatten the position. Current Position with working exit orders: 0. Current Position: 0. Current Position with exit market orders: 0 | 2015-05-21 19:47:48 Auto-Trading: Replay 60.0X: EURUSD 15 Min #1 | SpreadsheetTradeTest | SellEntry signal is ignored because maximum Short Position quantity allowed has been reached or would be exceeded with new order. Max. Position allowed: 1000. Resulting Position without existing orders: -10000. Resulting Position with existing orders: -10000 | Bar Start Time: 2015-04-23 15:00:00 | 2015-05-21 19:48:21 Auto-Trading: Replay 60.0X: EURUSD 15 Min #1 | SpreadsheetTradeTest | SellExit signal is ignored. Short position quantity does not exist or there are already working exit orders that will flatten the position. Current Position with working exit orders: 0. Current Position: 0. Current Position with exit market orders: 0 | 2015-05-21 19:48:48 ---/copy |
[2015-05-21 20:44:09] |
We will fix this. In our initial testing, it did work properly but when we increased the quantity to 10,000 we did not increase the maximum allowed position quantity.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-21 20:50:35
[2015-05-21 21:41:34] |
We have updated the files for the test procedure. They can be downloaded from this page again: http://www.sierrachart.com/index.php?page=doc/SpreadsheetTradingTestProcedure.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-07-08 04:27:09] |
User742717 Mike - Posts: 86 |
The spreadsheet file is blank.. ie no rules Oh I have to follow the rest of the instructions okay. Date Time Of Last Edit: 2015-07-08 04:29:24
