Date/Time: Sun, 22 Dec 2024 19:21:43 +0000
User Questions
View Count: 885
[2015-05-21 18:39:23] |
Sierra Chart - Max - Posts: 5756 |
I need to see tune indice CAC40 in realtime for research, but no trading, and no time restricition do i am right that the free version does not do that? and which one should i buy? can you name and save each type of chart , cac40 per mn, per, 10 mn, per hour, and call them separtly thanks you Sierra Chart Support |
[2015-05-21 19:25:41] |
To receive data in Sierra Chart for the CAC 40, requires that you use the Sierra Chart Real-time and Historical Forex/ CFD Data Service: Sierra Chart Real Time and Historical Forex and CFD Data Service To use this data service requires that you have Sierra Chart service package 1. You can find pricing on this page: Description of Service Packages and Pricing The symbol is FRA40. You will see this listed in File >> Find Symbol >> CFD. You can have multiple charts open. They can be of any timeframe per bar. These charts can all be saved as a Chartbook. Here are complete instructions: https://www.sierrachart.com/index.php?page=doc/doc_Chartbooks.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
