Date/Time: Sun, 22 Dec 2024 19:05:48 +0000
Simple MA of 5 min pivot
View Count: 1424
[2015-05-21 14:34:54] |
User884307 - Posts: 173 |
Hi, Im trying to display a simple moving average of say, a 5 min pivot point. The MA displays correctly but at the close of market the MA goes to zero. I have tried everything with regards to missing data etc etc etc but the problem will not go away. Also tried changing market open/close times but no result? It makes no difference if I use Volume bars, time bars etc. please help!! Many thanks |
[2015-05-21 17:49:46] |
Set the Auto Skip Period of No Trading study Input to Yes for the Pivot Points-Variable Period study.
[2015-05-21 19:35:03] |
Hi there, Yes already done that, it does improve things (in some cases anyhow) but still got the same problem? cheers |
[2015-05-21 19:59:38] |
Thinking about this, it would not totally solve the problem. You probably would have to create a Moving Average study that ignores zeros and use that. We will see if we can put something quickly together. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-21 20:00:01
[2015-05-23 03:37:34] |
A Moving Average-Simple which skips zeros will be out in the next release.
[2015-05-23 12:40:27] |
when is the next release due out? |
[2015-05-24 06:50:04] |
It is out now. Update with Help >> Download Prerelease. The study is listed under: Analysis >>Studies >> Studies Available >> Moving Average- Simple Skip Zeros
[2015-05-24 13:14:47] |
Ok will check it out. Many thanks ☺ |
[2015-05-24 13:24:39] |
..... Strange, just updated to latest 1258, cannot find moving averages skip zero in the list?
[2015-05-26 15:42:04] |
Any ideas on this? cheers :-)
[2015-05-26 20:42:04] |
You do not have the latest revision. How did you update?
[2015-05-26 20:43:48] |
Through the program update?
[2015-05-26 21:15:47] |
You need to use Help >> Download Prerelease.
