Date/Time: Sun, 22 Dec 2024 19:58:16 +0000
[User Discussion] - auto scale out
View Count: 14274
[2015-05-21 09:54:17]
jivetrader - Posts: 410
is it possible to use spreadsheet study for trading
to scale out over 3 TPs, or does this require acsil?
[2015-05-21 18:28:25]
You could use ACSIL:
https://www.sierrachart.com/index.php?page=doc/doc_ACSILTrading.html
However, you can use the scale out functionality with a Spreadsheet Trading system. Just follow through the documentation here for how to use it and how it works:
https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#ScalingOut
In general, scaling out is not simple with Spreadsheets. ACSIL would be better.
[2015-05-21 18:42:05]
if each TP requires a different technical signal to exit, can this be done in a Spreadsheet or does it require ACSIL
[2015-05-21 19:03:38]
You will need to use ACSIL because you cannot control multiple Targets individually from Spreadsheets.
[2015-05-21 19:27:28]
is there a template or something to start from for accomplishing this, as i am not familiar with ACSIL. if there was some kind of existing framework in place i could possibly modify it for my technical signals. i don't think i could build this from scratch.
[2015-05-23 03:55:54]
The place to start is this page:
[2015-05-25 00:42:21]
can anyone provide an ACSIL template for scaling out based on 3 different technical signals? no entry. i need some sort of starting point as i have very little coding experience. thanks
