Date/Time: Sun, 22 Dec 2024 19:05:36 +0000
scale in and out
View Count: 811
[2015-05-21 08:16:24] |
User934555 - Posts: 5 |
i use to use si and so without problema with sc , but the last day i realice this: i start with 3 lot, then i add 5, but the stop did not increase properly. the only change is now i am using cts insteat of rithmic is ther any adjust i need to do it to solve this? thanks |
[2015-05-21 09:54:24] |
You need to disable Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders to solve this problem.
