Date/Time: Mon, 16 Sep 2024 20:05:30 +0000
Use "CHASE " order disappear
View Count: 1224
[2015-05-20 16:14:51] |
User29582 - Posts: 33 |
in Version 1256, WHY? we need it |
[2015-05-20 16:41:25] |
Give an example of how you submit a Limit order so we can tell you how to submit a Limit Chase order instead.
[2015-05-23 09:07:30] |
rex2nd - Posts: 12 |
if using sell ask button ,how to activate the limit chase funtion? thanks Rex. |
[2015-05-23 10:47:52] |
OK we see, this is currently not supported. We would have to add a new command to support this. The Limit Chase order type can be added as a command to the Chart Trading menu and can be used on the chart DOM. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-05-24 02:30:57] |
Yes. We need Sell ASK and Buy Bid and "Chase". That's very critical. What's the " new command to support this"? When????????? You cannot random remove the old Good functions. That's Not professional. |
[2015-05-24 06:43:07] |
We will have this out this week. Limit Chase is still supported. If you press the Menu/M button on the Trade Window you will see an option to enable it for the Chart DOM and it can be added to the Chart Trade shortcut menu when you right-click on a chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-06-23 05:02:26] |
Bedhog - Posts: 173 |
I'm using v1261 and the limit chase switches back to limit in the trade window after placing an order. Having it set to limit chase is actually not working at the moment. Noticed it after switching brokers.
[2015-06-23 09:08:01] |
The way that Limit Chase orders are set is by enabling Menu >>Use Limit Chase Orders on the Trade Window.
