Date/Time: Wed, 16 Sep 2026 15:48:40 +0000
TPO Profile vs TPO Value area lines
View Count: 2015
| [2015-05-20 14:42:06] |
| markuz - Posts: 90 |
If i add a TPO profile chart and then a Value Area line study using the same time frames and input settings. Why are the lines several ticks off from the profile chart? I attached an image. |
| [2015-05-20 17:41:37] |
There must be some difference with settings. Refer to the information here about this: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#IncorrectValues It might be because the Value Area calculation method is different between the studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-20 17:41:50
| [2015-05-21 07:38:59] |
| JingIt - Posts: 44 |
I think SC hasn't update Count 2 levels at a time for value area for TPO value area lines study to match with new calculation method updated in version 1254 http://www.sierrachart.com/image.php?l=1432194252323.png p/s: As I am a market profile user, these features are in my really wish list. Single Feature Request: Singles for TPO Charts VPOC Extention when with TPO profile VOLUME PROFILE POC not extend Do you have any update on these features request SCE? Date Time Of Last Edit: 2015-05-21 07:44:31
| [2015-05-21 09:05:47] |
It is not accurate to apply a TPO Value Area Lines study directly to a TPO Profile Chart. This is documented here: http://www.sierrachart.com/index.php?page=doc/doc_TPOVolProfileCharts.html#UsingOtherStudies As long as you have set Count Two Levels at a Time for Value Area to Yes with the TPO Profile Chart and TPO Value Area Lines study, the calculation method is 100% identical. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-21 09:06:05
