Date/Time: Tue, 15 Sep 2026 13:56:22 +0000
chart trading confirmations
View Count: 1171
| [2015-05-19 23:13:42] |
| User120827 - Posts: 77 |
Is there any way to change the default settings for confirmations to be set to "off" on the chart trading ? Every time I attach a trade window to a chart, it has all of the confirmations checked off. Second question: If I have an autotrading strategy set up to use the attached orders, will those confirmation settings affect the autotrading ? e.g. If there is a confirmation required for new orders, will that block a a trade from being executed during autotrading ? shane |
| [2015-05-20 04:39:37] |
The default cannot be changed but once you set any of the settings on a Trade Window for a chart they remain so long as you save your charts as a Chartbook: Chartbooks (Workspaces) With auto trading, there are never confirmations displayed. All orders will go through automatically. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
