Date/Time: Sat, 12 Sep 2026 03:33:27 +0000
Question on Alert Conditions for Number Bars/Footprint
View Count: 1537
| [2015-05-19 21:13:37] |
| NumbersBars - Posts: 141 |
Is it possible to set alert base on the location of High Volume Node within a Number Bar/Footprint bar? For example, I would like to be alerted when High Volume Node of a Number Bar is at the TOP/HIGH of the bar (or any location within a number bar for that matter). Please refer to the attached screenshot. Is it possible to achieve that? if so, how? I have browsed through documentation but with no luck. Please help. Thanks. |
| [2015-05-20 04:30:07] |
Using Simple Alerts, there is not a straightforward way to get the highest volume at a price level within a Numbers Bar or two determine if it is at the top. You really need to use ACSIL for this: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
