Date/Time: Mon, 23 Dec 2024 00:57:48 +0000
ability to reset the trial
View Count: 1437
[2015-05-19 21:01:01] |
kinghat - Posts: 120 |
im looking to switch over to SC from NT but my trial has ran out and i need some more time to get used to it. is this possible?
[2015-05-19 21:37:35] |
We have reset the trial on your account. Restart Sierra Chart.
[2015-09-03 15:20:46] |
can i get another trial extension? i need to test something with my TST connection.
[2015-09-03 17:45:23] |
1. To purchase usage time, select "Help >> Add Usage Credit" on the Sierra Chart software menu. You can also go to this page in your browser: https://www.sierrachart.com/usercp.php?page=SCUsageTimePayments Login with your Sierra Chart Account Name and Password. 2. Choose the number Months you wish to pay for and the Service Package. 3. Choose one of the payment options. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-09-03 18:18:36] |
can you reset it for a day just to test one thing to see if i can get it working?
[2015-09-04 21:21:24] |
We apologize for the delay. We will do this now for you. If Sierra Chart is currently running restart it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-09-04 21:22:52
[2015-09-04 21:52:41] |
I have left for the holiday weekend. will I have access to this next week?
[2015-09-04 22:00:51] |
Yes.
