Date/Time: Sun, 22 Dec 2024 19:19:56 +0000
-1.#IO error - Sierra Won't display chart
View Count: 842
[2015-05-19 13:38:25] |
rhovega - Posts: 279 |
Hi can you please tell me why is this -1.#IO error coming up and how to solve it? Reloading the chart, changing instrument, and redownloading did not fix the issue. |
2015-05-19_9-25-06.png / V - Attached On 2015-05-19 13:38:08 UTC - Size: 32.76 KB - 351 views |
[2015-05-19 17:47:35] |
What we suspect is the study configuration you are using has a division by zero error. If you can determine what study this is occurring with, we can make sure this is prevented. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
