Date/Time: Sun, 27 Sep 2026 07:29:09 +0000
Scroll-Bar
View Count: 1265
| [2015-05-19 12:24:29] |
| MKL17 - Posts: 35 |
I have the scroll-bar disabled until the chart I am using is active. I have a number of windows detached from the chart window and the option to have scroll-bar hidden is helpful. Issue: In order to make the scroll-bar visible on a chart, I have to not only click on that chart but then go to another chart or two and click on those and then come back and click on the chart I am trying to see the scroll-bar on. |
| [2015-05-19 17:55:47] |
So you have enabled Global Settings >> General Settings >> Auto Hide Charts Title Bar and Scrollbar? If so, we cannot help with this. This is most definitely an operating system level problem and is a good example of why we do not like to implement this functionality because the operating system does not always reliably handle this. So if there is a problem with it, then we recommend not using it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
