Date/Time: Sun, 04 Oct 2026 20:52:10 +0000
[Locked] - Downloading historical charts
View Count: 1764
[2015-05-18 22:38:31]
User463662 - Posts: 50
I am trying to download historical charts on the ES. Right now, I can only get it to go back to the first of the year. And some of the data is missing up until March. How do I do this? I couldn't find anything on the support board.
[2015-05-19 04:33:20]
You need to use a Continuous Futures Contract chart. Refer to this page:
Continuous Futures Contract Charts
[2015-05-20 03:32:31]
What about downloading historical data for the NYSE Tick and NYSE A/D Line? I can't seem to get any data past last year? I was able to download historical charts on the ES after your advice above, but not as far back on the NYSE TICK and A/D Line.
[2015-05-20 04:31:41]
If you need data further back for these market statistics symbols, you need to use the Sierra Chart Historical Data Service:
For the NYSE TICK you need to use the symbol $TICK when using the SC Historical Data service.
[2015-05-23 19:29:02]
What symbol would I need for the NYSE Advance/Decline Line? Not the ratio, but the number of advancing stocks minus number of declining stocks. I found the current symbol but not the one I need for historical charts.
[2015-05-23 19:38:33]
I tried using $NSHF for the historical chart but it only takes me back to November of last year. I changed the days in the chart settings to further back then that, but I'm still not getting any dates beyond November 2014?
[2015-05-23 19:42:22]
I apologize, but I also can't get the NQ historical data to load past 2011.
[2015-05-24 06:35:09]
Is this an Intraday or Historical chart? It is extremely unlikely you would have a problem like this with a Historical chart.
For missing data issues for Historical charts, refer to help topic 6:
http://www.sierrachart.com/index.php?page=doc/helpdetails6.html
For missing data issues for Intraday charts, refer to:
http://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#MissingOrIncompleteIntradayChartData
Date Time Of Last Edit: 2015-05-24 06:37:15
[2015-05-24 22:56:01]
I was able to get $NSHF to load back to 2008. I still can't get NQ to go past 2011. And yes, they are both historical charts.
[2015-05-24 23:00:10]
For NQ it says,"No contract months found for symbol. Unable to build continuous futures contract chart." The next line reads,"There are no continuous futures contracts symbols. Loading data normally."
[2015-05-24 23:09:29]
What is the exact symbol of the chart?
And what is Global Settings >> Data/Trading Service Settings >>Service set to?
[2015-05-24 23:42:52]
SC historical data is what it's set too. The symbol is just NQ. I also just noticed my ES chart is missing chunks of dates. I tried following the troubleshooting guide about deleting and re-downloading the data, but that hasn't worked for me.
[2015-05-24 23:59:27]
These are not the correct symbols.
You can find the symbols in File >> Find Symbol.
For the NASDAQ futures the current symbol is NQM15
[2015-05-25 00:23:06]
Is the Russell TFM15?
[2015-05-25 00:25:24]
RJM15
[2015-05-25 00:34:40]
Wow, I've been using the wrong symbols. Thank you! Is there a way to search for symbols by typing words such as "Russell" or "Nasdaq"?
[2015-05-25 02:04:46]
Yes. You can find the symbols here:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures
You can use your web browser search function to search for the symbols on that page.
[2015-06-09 02:43:25]
The prices in my historical charts, at least for the ES, seem to be incorrect. I use a website which archives their daily tradeplans. None of the prices they were using match with my chart. As an example, I was simulating trades in 2011 on the ES and my historical prices were off by about 85 points compared with what the prices actually were at that time. Is there a way to fix this?
[2015-06-09 04:06:40]
Are you back adjusting the data with the Continuous Futures Contract option which back adjusts data?
[2015-06-10 02:33:47]
I think so. I've been choosing the option of Continuous Futures Contract - Date Rule Rollover - Back Adjusted. Is that what you mean?
[2015-06-10 05:49:00]
Yes this is the problem. Do not use one of the back adjusted Continuous Contract options.
[2015-06-10 11:52:57]
Whenever I don't have that option selected I can't get the full historical data though?
[2015-06-10 17:33:13]
This does not make sense if you use Continuous Futures Contract - Date Rule Rollover.
If there is any missing data when using that option, re-download the data for all contract months following the instructions here:
http://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#ReDownloading
[2015-06-12 04:37:12]
I get what you are saying to do now. Sorry. I switched over to the Date Rule Rollover without the back adjustment. That fixed the problem. Thank you.
