Date/Time: Sun, 22 Dec 2024 19:06:25 +0000
Moving trading dom settings and bracket order settings to another computer
View Count: 1213
[2015-05-18 19:06:10] |
User17052 - Posts: 30 |
Hi, I copied my chartbooks to another computer and it worked. I've changed colors for dom, profit and loss orders colors and also have created different custom bracket orders for ES, CL etc. How do I copy trading dom settings and bracket order settings to another computer? Thanks. |
[2015-05-19 04:34:43] |
Copy the following files: /Data/[Chartbook filename].CHT /Sierra3.CFG /Data/*.TWConfig Also refer to help topic 15: Http://www.sierrachart.com/index.php?page=doc/helpdetails15.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
