Date/Time: Sun, 22 Dec 2024 19:54:08 +0000
SC too slow
View Count: 1229
[2015-05-18 19:05:38] |
Peter Power - Posts: 70 |
Hi, since I updated my SC to 1241 it got much slower. My CPU is running at 60% and RAM at 50% but Sierra is choppy when I am moving the charts. In previous version I had the option to cut the data files based on certain amount of MB. I cannot find this option now. I found one option in data/trade service settings - data file management, where you can compress the data but when I run it it is like neverending story and it is trying to compress 256 files. Do you think this will help? Are there any other options how to improve performance? Thanx, P. |
[2015-05-18 20:36:20] |
Refer to help topic 30: Http://www.sierrachart.com/index.php?page=doc/helpdetails30.html Are you using Spreadsheets? Compressing the data files is not likely to help. Compressing the data files does take time. You potentially should allow many hours for that procedure. So it is recommended to do it over a weekend. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
