Date/Time: Fri, 24 Jan 2025 03:27:28 +0000
Link chart with Interactive Broker
View Count: 1458
[2015-05-18 17:50:09] |
Kinobe - Posts: 86 |
Hi Is it possible to link SC chart with watchlist on TWS (interactive broker)? when I click on stock on my TWS watchlist, linked graph will display chart of this stock. I know it is possible with multichart.net. |
[2015-05-18 17:51:35] |
No, this is not supported.
[2015-05-18 18:04:33] |
ok thank you. I would be a great feature. |
[2018-12-29 13:54:02] |
User513419 - Posts: 1 |
Hello, Can you please add this function: Link IB TWS scanner (Analytical Tools -> Advanced Market Scanner) with Sierrachart chart window. So that when you click stock ticker in TWS scanner it would load the stock chart in Sierracharts. Is it possible and how soon you could do this? |
