Date/Time: Sun, 22 Dec 2024 19:43:32 +0000
Last Price Display Question
View Count: 831
[2015-05-18 17:24:56] |
rwilliams1 - Posts: 346 |
When using the BAAVG to calculate the current price position, is it possible to have the price display label in the right side column match the BAAVG instead of displaying the last traded price?
[2015-05-18 20:52:17] |
In the Chart >> Chart Settings >> Trade and Current and Quote Symbol box enter the symbol with a -BAAVG suffix. Keep in mind you will not be able to trade from the chart when doing this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
