Date/Time: Sun, 22 Dec 2024 19:18:50 +0000
[User Discussion] - Freelancer needed
View Count: 1254
[2015-05-18 16:43:48]
EuropeanTrader - Posts: 290
I would like to have my bars colored in Sierra per following requirements. If you can do that for me, please let me know. I am willing to pay 25$. Thank you.
RULES FOR SWING HIGH AND LOW COLORING:
1. Swing high turns into a swing low and into a swing high and into a swing low etc. It must be this simple order so it cannot be a swing high and another swing high until there is a swing low. Simple but very important.
2. There is no "finished" swing as long as previous one is not confirmed.
3. What counts as a swing? Swing high definition: middle bar is the highest surrounded by at least 2 lower bars on each side. There can also be two middle bars the same height (max. 2) but they still need to be surrounded by two lower bars on each side. The opposite holds true for Swing low criteria.
4. There is one indicator that needs to be taken into account and its called Average true range (14). If swing is smaller then 1ATR of that exact time frame at the moment of calculation, then the swing does not exist and is ignored.
That's it.
Let's say leg into Swing high is colored blue/green and leg into Swing low is colored red. Unfinished leg is colored black (colors should be adjustable just in case of chart background color changes).
[2015-05-20 17:13:41]
User445352 - Posts: 13
You can use ZigZag indicator and config per your need.
[2015-05-21 14:33:12]
jwick - Posts: 142
I can make this for you if you still want it. What's your skype id / some way of contacting you?
[2015-05-21 15:16:43]
thank you User445352 for a suggestion. I am not really sure how to do that since my requirements aren't the same as ZigZag.
Tradersm please contact me at ... and we can move on from there. Thanks.
Date Time Of Last Edit: 2015-05-22 16:31:48
