Date/Time: Thu, 17 Sep 2026 23:51:40 +0000
Persistant nonbasic variable type
View Count: 1652
[2015-05-18 13:10:25]
Hendrixon - Posts: 130
I wrote a study that uses several "deque" collections. to make them persistent I made the deques global (yes with sc.FreeDLL = FALSE).
Study works fine when it's loaded once. I see now that to make the deques persistent per study instance I need to use "Dynamic Memory Allocation".
http://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#DynamicMemoryAllocations
I'm pretty stretched here with my programming abilities.
What should be changed in the code example above to use a deque there instead of an array?
[2015-05-19 04:51:40]
Look at the attached file for an example.
attachmentRequestValuesFromServerAndDraw.cpp - Attached On 2015-05-19 04:51:09 UTC - Size: 7.02 KB - 865 views
