Date/Time: Sun, 22 Dec 2024 19:16:12 +0000
Charts of futures spreads/ combinations with more than 2 contracts ?
View Count: 1632
[2015-05-17 18:44:52] |
Eric Cartman - Posts: 16 |
Hello, I like to use the "Difference (bar/ single line)" studies to chart the spreads I trade. However, it is limited to only 2 instruments, for example I can chart the spread between the Bund and the Bobl future. Is it somehow also possible in Sierra to chart spreads/ combinations of more than 2 instruments, for example a chart of long Bund, long Schatz and short Bobl ? Thank you :-) |
[2015-05-17 20:56:13] |
You can do with this with the Spread-3 Chart study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s53 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
