Date/Time: Sun, 22 Dec 2024 19:28:00 +0000
Help with timezones
View Count: 920
[2015-05-17 10:34:25] |
JRA - Posts: 97 |
I trade the Emini and set on the chart settings the official CME contract Specs. ie 5:00PM -4:15PM with Time zone on Advanced settings Chicago(-6CST/-5CDT). On Data/Trade Service Settings I set my country's Timezone. On my chart, which I am attaching together with all the settings I mentioned, the study Daily OHLC doesn't plot the correct High or Low of Yesterday. Further explanation is on the chart, pls advise what settings should I use. Thank you Ioannis R. |
chart.bmp - Attached On 2015-05-17 10:32:54 UTC - Size: 7.51 MB - 501 views My Timezone Settings.jpg / V - Attached On 2015-05-17 10:33:11 UTC - Size: 143.43 KB - 410 views ChartSettings1.jpg / V - Attached On 2015-05-17 10:33:22 UTC - Size: 149.42 KB - 387 views ChartSettings2.jpg / V - Attached On 2015-05-17 10:33:29 UTC - Size: 169.22 KB - 428 views |
[2015-05-17 19:51:29] |
The Session Times in the chart must use Chicago/US Central times. Not Athens. Also when providing an image of the chart only use this method described here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-05-17 19:51:55
[2015-05-17 22:07:36] |
JRA - Posts: 97 |
My chart is using Chicago/US CT. Athens is used on Data\Trade settings. Should I change this as well?
[2015-05-17 22:41:51] |
Therefore, use a Start Time of 15:15:0 and an End Time of 15:14:59
