Date/Time: Tue, 29 Sep 2026 03:39:13 +0000
ASCIL trading examples that come with SC
View Count: 4715
| [2015-05-16 02:34:54] |
| User120827 - Posts: 77 |
hi SC has many great ASCIL code examples like the trading example for crossovers. I was hoping to find a similar sample for something other than a crossover. Perhaps a " greater than " sample. In order to add a filter like " if 20 SMA > 50 SMA " Are there other sources for ASCIL sample codes for SC ? shane Date Time Of Last Edit: 2015-05-16 02:35:33
| [2015-05-16 08:39:45] |
Tell us what specific ACSIL trading example you are looking at. Tell us the function name and then we will modify it to do what you are asking for.
| [2015-05-16 20:42:52] |
hi This was the example crossover code that is with many other codes under tradingsystems file in the ACS soure folder. SCSFExport scsf_SC_TradingCrossOverExample(SCStudyGraphRef sc) SCSFExport scsf_SC_TradingCrossOverExample(SCStudyGraphRef sc)
{ SCInputRef Line1Ref = sc.Input[0]; SCInputRef Line2Ref = sc.Input[1]; SCSubgraphRef BuyEntry = sc.Subgraph[0]; SCSubgraphRef SellEntry = sc.Subgraph[1]; if (sc.SetDefaults) { // Set the configuration and defaults sc.GraphName = "Trading CrossOver Example"; sc.StudyDescription = "An example of a trading system that enters a new position or \ reverses an existing one on the crossover of two study Subgraphs. \ When line1 crosses line2 from below, the system will look to be long. \ When line1 crosses line2 from above, the system will look to be short."; sc.AutoLoop = 1; // true sc.GraphRegion = 0; sc.FreeDLL = 0; sc.CalculationPrecedence = LOW_PREC_LEVEL; Line1Ref.Name = "Line1"; Line1Ref.SetStudySubgraphValues(1, 0); Line2Ref.Name = "Line2"; Line2Ref.SetStudySubgraphValues(1, 0); BuyEntry.Name = "Buy"; BuyEntry.DrawStyle = DRAWSTYLE_POINTHIGH; BuyEntry.LineWidth = 3; SellEntry.Name = "Sell"; SellEntry.DrawStyle = DRAWSTYLE_POINTLOW; SellEntry.LineWidth = 3; sc.AllowMultipleEntriesInSameDirection = false; sc.MaximumPositionAllowed = 5; sc.SupportReversals = true; // This is false by default. Orders will not go to the external connected trading service. sc.SendOrdersToTradeService = false; sc.AllowOppositeEntryWithOpposingPositionOrOrders = false; // This can be false in this function because we specify Attached Orders directly with the order which causes this to be considered true when submitting an order. sc.SupportAttachedOrdersForTrading = false; sc.CancelAllOrdersOnEntriesAndReversals= true; sc.AllowEntryWithWorkingOrders = false; sc.CancelAllWorkingOrdersOnExit = true; // Only 1 trade for each Order Action type is allowed per bar. sc.AllowOnlyOneTradePerBar = true; //This needs to be set to true when a trading study uses trading functions. sc.MaintainTradeStatisticsAndTradesData = true; return; } // only process at the close of the bar; if it has not closed don't do anything if (sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_NOT_CLOSED) { return; } // using the line1Ref and line2Ref input variables, retrieve the subgraph arrays into line1, line2 arrays respectively SCFloatArray line1; sc.GetStudyArrayUsingID(Line1Ref.GetStudyID(), Line1Ref.GetSubgraphIndex(), line1); SCFloatArray line2; sc.GetStudyArrayUsingID(Line2Ref.GetStudyID(), Line2Ref.GetSubgraphIndex(), line2); // code below is where we check for crossovers and take action accordingly if (sc.CrossOver(line1, line2) == CROSS_FROM_BOTTOM) { // mark the crossover on the chart BuyEntry[sc.Index] = 1; // Create a market order and enter long. s_SCNewOrder order; order.OrderQuantity = 1; order.OrderType = SCT_ORDERTYPE_MARKET; sc.BuyEntry(order); } if (sc.CrossOver(line1, line2) == CROSS_FROM_TOP) { // mark the crossover on the chart SellEntry[sc.Index] = 1; // create a market order and enter short s_SCNewOrder order; order.OrderQuantity = 1; order.OrderType = SCT_ORDERTYPE_MARKET; sc.SellEntry(order); } } i think the function I was in this section I was hoping to modify or add to the existing code. if (sc.CrossOver(line1, line2) == CROSS_FROM_BOTTOM)
{ // mark the crossover on the chart BuyEntry[sc.Index] = 1; // Create a market order and enter long. s_SCNewOrder order; order.OrderQuantity = 1; order.OrderType = SCT_ORDERTYPE_MARKET; sc.BuyEntry(order); } |
